Datasheet ERA-5+ Full Version (Mini-Circuits) - 4
ManufacturerMini-Circuits
DescriptionDrop-In Monolithic Amplifier DC-4 GHz
Pages / Page23 / 4 — Monolithic InGaP HBT MMIC Amplifier. ERA-5+. ESD Rating. MSL Rating. NO. …
Monolithic InGaP HBT MMIC Amplifier. ERA-5+. ESD Rating. MSL Rating. NO. TEST REQUIRED. CONDITION. STANDARD. QUANTITY
Monolithic InGaP HBT MMIC Amplifier ERA-5+ ESD Rating MSL Rating NO TEST REQUIRED CONDITION STANDARD QUANTITY
Human Body Model (HBM): Class 1B (500 v to < 1,000 v) in accordance with ANSI/ESD STM 5.1 - 2001 Machine Model (MM): Class M1 (< 100 v) in accordance with ANSI/ESD STM 5.2 - 1999
MSL Rating
Moisture Sensitivity: MSL1 in accordance with IPC/JEDECJ-STD-020C
NO. TEST REQUIRED CONDITION STANDARD QUANTITY
Low Power Microscope MIP-IN-0003 1 Visual Inspection 45 units Magnification 40x (MCT spec) SCD 2 Electrical Test Room Temperature 45 units (MCL spec) Less than 10% growth in term of J-Std-020C 3 SAM Analysis 45 units delamination (Jedec Standard) Bake at 125°C for 24 hours Moisture Sensitivity J-Std-020C 4 Soak at 85°C/85%RH for 168 hours 45 units Level 1 (Jedec Standard) Reflow 3 cycles at 260°C peak
MSL Test Flow Chart
Start Visual Electrical Test SAM Analysis Inspection Soak Reflow 3 cycles, Bake at 125°C, 85°C/85RH 260°C 24 hours 168 hours Visual Electrical Test SAM Analysis Inspection Stop Notes A. Performance and quality attributes and conditions not expressly stated in this specification document are intended to be excluded and do not form a part of this specification document. B. Electrical specifications and performance data contained in this specification document are based on Mini-Circuit’s applicable established test performance criteria and measurement instructions. C. The parts covered by this specification document are subject to Mini-Circuits standard limited warranty and terms and conditions (collectively, “Standard Terms”); Purchasers of this part are entitled to the rights and benefits contained therein. For a full statement of the Standard Terms and the exclusive rights and remedies thereunder, please visit Mini-Circuits’ website at www.minicircuits.com/MCLStore/terms.jsp
Mini-Circuits
P.O. Box 350166, Brooklyn, NY 11235-0003 (718) 934-4500 sales@minicircuits.com Page 4 of 4 Document Outline ERA-5+ Data Sheet View Data View Graphs Case Style Tape and Reel PCB Layout Eval Board Enviromental Ratings
