Datasheet AD8608-KGD (Analog Devices) - 6
DescriptionLow Noise, CMOS, Rail-to-Rail, Input/Output Precision Quad Op Amp
Pages / Page7 / 6 — AD8608-KGD. Known Good Die. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. …
File Format / SizePDF / 170 Kb
AD8608-KGD. Known Good Die. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. 11B. 11A. NC 8. Table 4. Pad Function Descriptions Pad
AD8608-KGD Known Good Die PIN CONFIGURATION AND FUNCTION DESCRIPTIONS 11B 11A NC 8 Table 4 Pad Function Descriptions Pad
AD8608-KGD Known Good Die PIN CONFIGURATION AND FUNCTION DESCRIPTIONS 1 14 2 13 3 12 4A 11B 4B 11A 5 10 6 9 7 NC 8 NC
001 13166- Figure 1. Pad Configuration
Table 4. Pad Function Descriptions Pad X-Axis (µm) Y-Axis (µm) Mnemonic Pad Type Description
1 −490 +1239 OUT A Single Output Channel A 2 −749 +1153 − IN A Single Inverting Input Channel A 3 −749 +853 + IN A Single Noninverting Input Channel A 4A −703 +85 V+ Supply Double Positive Supply Voltage 4B −703 −84 V+ Supply Double Positive Supply Voltage, Double Bond Pad 5 −749 −659 + IN B Single Noninverting Input Channel B 6 −749 −944 − IN B Single Inverting Input Channel B 7 −683 −1189 OUTB Single Output Channel B 8 +688 −1189 OUTC Single Output Channel C 9 +749 −916 − IN C Single Inverting Input Channel C 10 +749 −631 + IN C Single Noninverting Input Channel C 11A +749 −122 V− Supply Double Negative Supply Voltage 11B +749 +47 V− Supply Double Negative Supply Voltage, Double Bond Pad 12 +749 +813 + IN D Single Noninverting Input Channel D 13 +749 +1113 − IN D Single Inverting Input Channel D 14 +597 +1239 OUT D Single Output Channel D Rev. 0 | Page 6 of 7 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 5 V ELECTRICAL SPECIFICATIONS 2.7 V ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
