Datasheet AD8039 (Analog Devices) - 8
DescriptionLow Power, 350 MHz Voltage Feedback Amplifiers
Pages / Page13 / 8 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/12644
File Format / SizePDF / 74 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/12644
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions Temperature, Device Limits Unit VS = 5 V, RL = 2 k to VS/2, TA type gain = +1, Min Max unless otherwise specified Dynamic performance. -3 dB bandwidth G = +1, VOUT = 0.2 Vpp -55C to +105C 01 275 MHz G = +2, VOUT = 0.2 Vpp +25C 150 typical G = +1, VOUT = 2 Vpp +25C 30 typical Bandwidth for 0.1 dB G = +2, VOUT = 0.2 Vpp +25C 01 45 typical MHz flatness Slew rate SR G = +1, VOUT = 2 V step, RL = 2 k +25C 01 340 V/s -55C to +105C 275 Overdrive recovery G = +2, 1 V overdrive +25C 01 50 typical ns time Settling time to 0.1% G = +2, VOUT = 2 V step +25C 01 18 typical ns Noise/harmonic performance. Signal frequency distortion response (SFDR) Second harmonic fc = 1 MHz, VOUT = 2 Vpp, +25C 01 -82 typical dBc RL = 2 k Third harmonic fc = 1 MHz, VOUT = 2 Vpp, +25C 01 -79 typical dBc RL = 2 k Second harmonic fc = 5 MHz, VOUT = 2 Vpp, +25C 01 -60 typical dBc RL = 2 k Third harmonic fc = 5 MHz, VOUT = 2 Vpp, +25C 01 -67 typical dBc RL = 2 k Crosstalk, CT f = 5 MHz, G = +2 +25C 01 -70 typical dB output to output Input voltage noise f = 100 kHz +25C 01 8 typical nV/ Hz Input current noise f = 100 kHz +25C 01 600 typical fA/ Hz See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12644
REV A PAGE 8
