Datasheet OP262 (Analog Devices) - 6
Description15 MHz Rail-to-Rail Operational Dual Op Amp
Pages / Page11 / 6 — Input characteristics. Output characteristics. Power supply. Dynamic …
File Format / SizePDF / 213 Kb
Input characteristics. Output characteristics. Power supply. Dynamic performance. Noise performance. DLA LAND AND MARITIME
Input characteristics Output characteristics Power supply Dynamic performance Noise performance DLA LAND AND MARITIME
TABLE I. Electrical performance characteristics - Continued. 1/ Test Symbol Test conditions Limits Unit VS = 3.0 V, VCM = 0 V Min Typ Max TA = 25°C unless otherwise specified
Offset voltage VOS 50 325 µV -55°C ≤ TA ≤ +125°C 1 mV Input bias current IS 360 600 nA Input offset current IOS ±2.5 ±25 Input voltage range VCM 0 2 V Common mode rejection CMRR 0 V ≤ VCM ≤ 4.0 V, -55°C ≤ TA ≤ +125°C 70 110 dB Large signal voltage gain AVO RL = 2 kΩ, 0.5 V ≤ VOUT ≤ 2.5 V 20 V/mV RL = 10 kΩ, 0.5 V ≤ VOUT ≤ 2.5 V 20 30
Output voltage swing high VOH IL = 250 µA 2.95 2.99 V IL = 5 mA 2.85 2.93 Output voltage swing low VOL IL = 250 µA 14 50 mV IL = 5 mA 66 150
Power supply
Power supply rejection ratio PSRR VS = 2.7 V to 7 V 110 dB -55°C ≤ TA ≤ +125°C 60 Supply current/Amplifier ISY VOUT = 1.5 V 500 650 µA -55°C ≤ TA ≤ +125°C 850
Dynamic performance
Slew rate SR RL = 10 kΩ 10 V/µs Settling time tS To 0.1%, AV = -1, VO = 2 V step 575 ns Gain bandwidth product GBP 15 MHz Phase margin ᵩm 59 Degrees
Noise performance
Voltage noise en p-p 0.1 Hz to 10 Hz 0.5 µV p-p Voltage noise density en f = 1 kHz 9.5 nV/√Hz Current noise density in f = 1 kHz 0.4 pA/√Hz See footnote at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12639
REV PAGE 6 Document Outline DESCRIPTION REV REV PMIC N/A TITLE SIZE A V62/12639 REV
