Datasheet AD8041 (Analog Devices) - 7
Description160 MHz Rail-to-Rail Amplifier with Disable
Pages / Page13 / 7 — STANDARD. 5962-96839. MICROCIRCUIT DRAWING
File Format / SizePDF / 97 Kb
STANDARD 5962-96839 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics – continued. Conditions 1/ 2/ 3/ Test Symbol -55C  TA +125C Group A Device Limits Unit unless otherwise specified subgroups type Min Max Open loop gain AOL RL = 1 k 1,2,3 All 15 kV/V M,D,P,L,R 1 02 15 M,D,P,L 1 03 15 Positive output swing +VOUT RL = 1 k 1,2,3 All 1.75 V voltage M,D,P,L,R 1 02 1.75 M,D,P,L 1 03 1.75 RL = 50 1,2,3 All 1.45 M,D,P,L,R 1 02 1.45 M,D,P,L 1 03 1.45 Negative output swing -VOUT RL = 1 k 1,2,3 All -2.15 V voltage M,D,P,L,R 1 02 -2.15 M,D,P,L 1 03 -2.15 RL = 50 1,2,3 All -1.5 M,D,P,L,R 1 02 -1.5 M,D,P,L 1 03 -1.5 1/ Unless otherwise specified, VS = 2.5 V and load resistance (RL) = 2 k to 0.0 V. This is equivalent to +VS = +5 V, -VS = 0 V, and load resistance (RL) = 2 k to 2.5 V. 2/ Device type 02 supplied to this drawing has been characterized through all levels M, D, P, L, R of irradiation. Device type 03 supplied to this drawing has been characterized through all levels M, D, P and L of irradiation. However, device type 02 is only tested at the R level and device type 03 is only tested at L level. Pre and Post irradiation values are identical unless otherwise specified in Table I. When performing post irradiation electrical measurements for any RHA level, TA = +25C. 3/ For device type 02, this part may be dose rate sensitive in a space environment and may demonstrate enhanced low dose rate effects. Radiation end point limits for the noted parameters are guaranteed only for the conditions specified in MIL-STD-883, method 1019, condition A for device type 02. Device type 03 has been tested at a low dose rate. For device type 03, radiation endpoint limits for the noted parameters are guaranteed for the condition specified in MIL-STD-883, method 1019, condition D 4/ Disabled mode: the device has an active low disable bar pin which can be used to three state the output of the part and also lower its supply current. If the disable bar pin is left floating, the part is enabled and will perform normally. If the disable pin is pulled to 2.5 V (minimum) below the positive supply, the output of the device will be disabled and the IS supply current will drop to IS disabled specification in Table I. For best isolation, the disable pin should be pulled to as low as possible, ideally the -VS supply rail.
STANDARD
SIZE
5962-96839 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 F 7 DSCC FORM 2234 APR 97
