1.3 Absolute maximum ratings. 1/ Supply voltage (VS) ... 12.6 V Input voltage (common mode) ... ±VS Differential input voltage .. ±1.2 V Power dissipation (PD) .. 0.9 W 2/ Storage temperature range .. -65°C to +150°C Lead temperature range (soldering, 60 seconds) .. +300°C Thermal resistance, junction-to-case (θJC) .. See MIL-STD-1835 Thermal resistance, junction-to-ambient (θJA) Case P ... 110°C/W Case H .. 120°C/W 1.4 Recommended operating conditions. Supply voltage (VS) ... ±5 V Ambient operating temperature range (TA) ... -55°C to +125°C 1.5 Radiation features: Device type 01: Maximum total dose available (dose rate = 50 – 300 rads(Si)/s) ... 100 krads (Si) 3/ Device type 02: Maximum total dose available (dose rate ≤ 10 mrads(Si)/s) .. 50 krads (Si) 4/ 2. APPLICABLE DOCUMENTS 2.1 Government specification, standards, and handbooks. The following specification, standards, and handbooks form a part of this drawing to the extent specified herein. Unless otherwise specified, the issues of these documents are those cited in the solicitation or contract. DEPARTMENT OF DEFENSE SPECIFICATION MIL-PRF-38535 - Integrated Circuits, Manufacturing, General Specification for. DEPARTMENT OF DEFENSE STANDARDS MIL-STD-883 - Test Method Standard Microcircuits. MIL-STD-1835 - Interface Standard Electronic Component Case Outlines. DEPARTMENT OF DEFENSE HANDBOOKS MIL-HDBK-103 - List of Standard Microcircuit Drawings. MIL-HDBK-780 - Standard Microcircuit Drawings. (Copies of these documents are available online at https://assist.dla.mil/quicksearch/ or from the Standardization Document Order Desk, 700 Robbins Avenue, Building 4D, Philadelphia, PA 19111-5094.) ________ 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability. 2/ Maximum internal power dissipation is specified so that the junction temperature dose not exceed +175°C. Derate at 9mW/°C for TA > +32°C. 3/ Device type 01 may be dose rate sensitive in a space environment and may demonstrate enhanced low dose rate effects. Radiation end point limits for the noted parameters are guaranteed only for the conditions specified in MIL-STD-883, method 1019, condition A. 4/ For device type 02, radiation end point limits for the noted parameters are guaranteed for the conditions specified in MIL- STD-883, method 1019, condition D. STANDARD SIZE 5962-94593MICROCIRCUIT DRAWINGA DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 E 3 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
