Datasheet AD822 (Analog Devices) - 3
DescriptionSingle-Supply, Rail-to-Rail Low Power FET-Input Dual Op Amp
Pages / Page17 / 3 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/12636
File Format / SizePDF / 101 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/12636
1.3 Absolute maximum ratings. 1/ Supply voltage range (VS) .. 18 V Input voltage (VIN) .. +VS + 0.2 V to –VS – 20 V Output short duration ... Indefinite Differential input voltage ... 30 V Internal power dissipation (PD) .. 156.25 mW typical Maximum junction temperature (TJ) .. 150C Storage temperature range (TSTG) .. -65C to +150C Lead temperature (soldering, 60 seconds) ... +260C 1.4 Recommended operating conditions. 2/ Supply voltage range (VS) .. 15 V Operating temperature range (TA) .. -55C to +125C 1.5 Thermal characteristics. Thermal resistance, junction to case (JC) ... 43C/W Thermal resistance, junction to ambient (JA) .. 160C/W 1/ Stresses beyond those listed under “absolute maximum rating” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2/ Use of this product beyond the manufacturers design rules or stated parameters is done at the user’s risk. The manufacturer and/or distributor maintain no responsibility or liability for product used beyond the stated limits.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12636
REV A PAGE 3
