Datasheet OP497 (Analog Devices) - 3
DescriptionPrecision Picoampere Input Current Quad Operational Amplifier
Pages / Page10 / 3 — STANDARD. 5962-94521. MICROCIRCUIT DRAWING
File Format / SizePDF / 63 Kb
STANDARD 5962-94521 MICROCIRCUIT DRAWING
1.3 Absolute maximum ratings. 1/ Supply voltage (VCC) .. ±20 V Differential input voltage ... 40 V 2/ Input voltage ... Supply voltage 2/ Output short-circuit duration ... Continuous Power dissipation (PD) ... 800 mW Storage temperature range .. –65C to +175C Lead temperature range (soldering, 60 seconds) ... +300C Junction temperature (TJ) ... –65C to +175C Thermal resistance, junction-to-case (JC) ... See MIL-STD-1835 Thermal resistance, junction-to-ambient (JA): Case C ... 94C/W Case 2 .. 78C/W 1.4 Recommended operating conditions. Supply voltage (VCC) .. 15 V Ambient operating temperature (TA) .. -55C to +125C 2. APPLICABLE DOCUMENTS 2.1 Government specification, standards, and handbooks. The following specification, standards, and handbooks form a part of this drawing to the extent specified herein. Unless otherwise specified, the issues of these documents are those cited in the solicitation or contract. DEPARTMENT OF DEFENSE SPECIFICATION MIL-PRF-38535 - Integrated Circuits, Manufacturing, General Specification for. DEPARTMENT OF DEFENSE STANDARDS MIL-STD-883 - Test Method Standard Microcircuits. MIL-STD-1835 - Interface Standard Electronic Component Case Outlines. DEPARTMENT OF DEFENSE HANDBOOKS MIL-HDBK-103 - List of Standard Microcircuit Drawings. MIL-HDBK-780 - Standard Microcircuit Drawings. (Copies of these documents are available online at http://quicksearch.dla.mil or from the Standardization Document Order Desk, 700 Robbins Avenue, Building 4D, Philadelphia, PA 19111-5094.) ______ 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability. 2/ For supply voltages less than 20 V, the absolute maximum input voltage is equal to the supply voltage.
STANDARD
SIZE
5962-94521 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 C 3 DSCC FORM 2234 APR 97
