Datasheet AD844 (Analog Devices) - 5
Description | 60 MHz, 2000 V/μs, Monolithic Op Amp with Quad Low Noise |
Pages / Page | 12 / 5 — STANDARD. 5962-89644. MICROCIRCUIT DRAWING |
File Format / Size | PDF / 75 Kb |
TABLE I. Electrical performance characteristics. Conditions 1/ 2/ Test Symbol -55C TA +125C Group A Device Limits 3/ Unit V subgroups type S = 15 V unless otherwise specified Min Max Input offset voltage VIO VCM = 0 V 4/ 1 01, 02 -300 +300 V 2,3 -500 +500 M,D,P,L,R 1 01 -1000 +1000 M,D,P,L 02 -1000 +1000 Power supply rejection +VS = +5 V to +18 V, 5/ +PSRR 1,2,3 01, 02 20 V/V ratio -VS = -15 V -VS = -5 V to -18 V, 5/ -PSRR 20 +VS = +15 V Output voltage swing +VOUT RL = 500 5/ 1,2,3 01, 02 10 V -VOUT -10 Quiescent current IQ VOUT = 0 V 5/ 1 01, 02 7.5 mA 2,3 9.5 Input bias current -IIB VCM = 0 V 6/ 1 01, 02 -450 +450 nA 2,3 -2500 +2500 M,D,P,L,R 1 01 -2500 +2500 M,D,P,L 02 -2500 +2500 +IIB VCM = 0 V 6/ 1 01, 02 -400 +400 2,3 -1300 +1300 M,D,P,L,R 1 01 -1300 +1300 M,D,P,L 02 -1300 +1300 +I Common mode input VR 5/ 7/ 1,2,3 01, 02 +10 V voltage range -IVR -10 Open loop transresistance TZ VOUT = 10 V, 1 01, 02 2.2 M RL = 500 2,3 1.3 M,D,P,L,R 1 01 1.3 M,D,P,L 02 1.3 See footnotes at end of table.
STANDARD
SIZE
5962-89644 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990
E 5
DSCC FORM 2234 APR 97
