Datasheet AD713 (Analog Devices) - 7
DescriptionPrecision, High Speed, BiFET Quad Op Amp
Pages / Page12 / 7 — STANDARD. 5962-90633. MICROCIRCUIT DRAWING
File Format / SizePDF / 123 Kb
STANDARD 5962-90633 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics – Continued. Conditions Test Symbol -55°C ≤ TA ≤ +125°C Group A Device Limits Unit V subgroups type S = ±15 V unless otherwise specified Min Max Unity gain bandwidth 3/ UGBW RL = 2 kΩ, AV = 1, 4 01 3.0 MHz TA = +25°C 02 3.4 Settling time 3/ t 9 All 1.2 µs SET Measured at .01% at 10 V step, TA = +25°C 1/ Input offset voltage specifications apply with VOS unnulled. 2/ Bias current specifications apply after five minutes of operation at TA = +25°C. For TA > +25°C, the current doubles every +10°C. 3/ If not tested, shall be guaranteed to the limits specified in table I herein. 4/ Matching is defined as the difference between parameters of any two amplifiers.
STANDARD
SIZE
5962-90633 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 B 7 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
