Datasheet OP97 (Analog Devices) - 9
DescriptionLow Power, High Precision Operational Amplifier
Pages / Page9 / 9 — STANDARD. MICROCIRCUIT. DRAWING. BULLETIN. DATE:. 12-11-14. Approved. …
File Format / SizePDF / 84 Kb
STANDARD. MICROCIRCUIT. DRAWING. BULLETIN. DATE:. 12-11-14. Approved. sources. of. supply. for. SMD. 5962-89544. are. listed. below. for. immediate
STANDARD MICROCIRCUIT DRAWING BULLETIN DATE: 12-11-14 Approved sources of supply for SMD 5962-89544 are listed below for immediate
STANDARD MICROCIRCUIT DRAWING BULLETIN DATE: 12-11-14 Approved sources of supply for SMD 5962-89544 are listed below for immediate acquisition information only and shall be added to MIL-HDBK-103 and QML-38535 during the next revision. MIL-HDBK-103 and QML-38535 will be revised to include the addition or deletion of sources. The vendors listed below have agreed to this drawing and a certificate of compliance has been submitted to and accepted by DLA Land and Maritime -VA. This information bulletin is superseded by the next dated revision of MIL-HDBK-103 and QML-38535. DLA Land and Maritime maintains an online database of all current sources of supply at http://www.landandmaritime.dla.mil/Programs/Smcr/. Standard Vendor Vendor microcircuit drawing CAGE similar PIN 1/ number PIN 2/ 5962-8954401GA 3/ OP-97AJ/883 5962-8954401PA 24355 OP-97AZ/883 1/ The lead finish shown for each PIN representing a hermetic package is the most readily available from the manufacturer listed for that part. If the desired lead finish is not listed contact the vendor to determine its availability. 2/ Caution. Do not use this number for item acquisition. Items acquired to this number may not satisfy the performance requirements of this drawing. 3/ Not available from an approved source of supply. Vendor CAGE Vendor name number and address 24355 Analog Devices Route 1 Industrial Park P.O. Box 9106 Norwood, MA 02062 Point of contact: 804 Woburn Street Wilmington, MA 01887-3462 The information contained herein is disseminated for convenience only and the Government assumes no liability whatsoever for any inaccuracies in the information bulletin.
