Datasheet OP471 (Analog Devices) - 3
DescriptionHigh Speed, Low Noise Quad Operational Amplifier
Pages / Page13 / 3 — STANDARD. 5962-88565. MICROCIRCUIT DRAWING
File Format / SizePDF / 81 Kb
STANDARD 5962-88565 MICROCIRCUIT DRAWING
1.2.4 Case outline(s). The case outline(s) are as designated in MIL-STD-1835 and as follows: Outline letter Descriptive designator Terminals Package style C GDIP1-T14 or CDIP2-T14 14 Dual-in-line D GDFP1-F14 or CDFP2-F14 14 Flat pack 2 CQCC1-N20 20 Square leadless chip carrier 3 CQCC1-N28 28 Square leadless chip carrier K GDFP2-F24 or CDFP3-F24 24 Flat pack 1.2.5 Lead finish. The lead finish is as specified in MIL-PRF-38535 for device classes Q and V or MIL-PRF-38535, appendix A for device class M. 1.3 Absolute maximum ratings. 1/ Supply voltage (VCC) ... 18 V dc Differential input voltage .. 1 V dc 2/ Differential input current .. 25 mA 2/ Input voltage .. Supply voltage Output short circuit duration ... Continuous Storage temperature range ... -65C to +150C Lead temperature (soldering, 60 seconds) .. +300C Power dissipation (PD): Cases C and 2 ... 800 mW Case D ... 550 mW Case 3 .. 500 mW Case K ... 440 mW Maximum junction temperature (TJ) .. +150C Thermal resistance, junction-to-case (JC) .. See MIL-STD-1835 Thermal resistance, junction-to-ambient (JA): Cases C and 2 ... 100C/W Case D ... 140C/W Case 3 .. 110C/W Case K ... 69C/W 1.4 Recommended operating conditions. Ambient operating temperature range (TA) ... -55C to +125C Supply voltage (VCC) ... 15 V 1.5 Radiation features. Device types 01 and 02: Maximum total dose available (dose rate = 50 – 300 rads(Si)/s) ... 100 krads(Si) 3/ Device types 03 and 04: Maximum total dose available (dose rate  10 mrads(Si)/s) .. 50 krads (Si) 4/ 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability. 2/ The inputs are protected by back-to-back diodes. Current limiting resistors are not used in order to achieve low noise performance. If the differential input voltage exceeds 1 V, the input current should be limited to 25 mA. 3/ Device types 01 and 02 may be dose rate sensitive in a space environment and may demonstrate enhanced low dose rate effects. Radiation end point limits for the noted parameters are guaranteed only for the conditions specified in MIL-STD-883, method 1019, condition A. 4/ For device type 03 and 04, radiation end point limits for the noted parameters are guaranteed for the conditions specified in MIL-STD-883, method 1019, condition D.
STANDARD
SIZE
5962-88565 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990
J 3
DSCC FORM 2234 APR 97
