Datasheet AD712-EP (Analog Devices) - 6
DescriptionDual Precision, Low Cost, High Speed BiFET Op Amp
Pages / Page12 / 6 — ) 15. m (. E S. RRE. G A 10. RL = 2kΩ. 25°C. IE U. SUPPLY VOLTAGE ± V. …
File Format / SizePDF / 206 Kb
) 15. m (. E S. RRE. G A 10. RL = 2kΩ. 25°C. IE U. SUPPLY VOLTAGE ± V. 106. s) p. 107. G IN. OUT. 108. –VOUT. T 10. 109. VO T. URRE. 1010. BI T U 1011 INP. 1012. –60
) 15 m ( E S RRE G A 10 RL = 2kΩ 25°C IE U SUPPLY VOLTAGE ± V 106 s) p 107 G IN OUT 108 –VOUT T 10 109 VO T URRE 1010 BI T U 1011 INP 1012 –60
AD712-EP TYPICAL PERFORMANCE CHARACTERISTICS
20 6 ) 15 A) (V 5 G m ( IN T W N E S RRE G A 10 4 T CU L RL = 2kΩ NT VO 25°C CE T S PU IE U IN 5 3 Q 0
5 02
2 0 5 10 15 20
0 00 5-
0 5 10 15 20
5-
SUPPLY VOLTAGE ± V
28 28 09
SUPPLY VOLTAGE ± V
09 Figure 2. Input Voltage Swing vs. Supply Voltage Figure 5. Quiescent Current vs. Supply Voltage
20 106 s) p ) 107 m (V A 15 ( G IN +V 0) OUT W = 108 –VOUT CM E S V G ( A T T 10 N 109 L RL = 2kΩ VO T 25°C URRE U C P 1010 T AS U 5 O BI T U 1011 INP 0
03
1012 0 5 10 15 20
0 06 5-
–60 –40 –20 0 20 40 60 80 100 120 140
0 5-
SUPPLY VOLTAGE ± V
28 28 09
TEMPERATURE (°C)
09 Figure 3. Output Voltage Swing vs. Supply Voltage Figure 6. Input Bias Current vs. Temperature
30 100 ) 25 -p p V ) 10 ( (Ω 20 ING W S ±15V SUPPLIES E DANCE E 15 P 1.0 AG T M L I O UT V 10 P UT UT P O 0.1 UT O 5 0 0.01
04 07
10 100 1k 10k
0
1k 10k 100k 1M 10M
0 5- 5- 28
LOAD RESISTANCE (Ω)
28
FREQUENCY (Hz)
09 09 Figure 4. Output Voltage Swing vs. Load Resistance Figure 7. Output Impedance vs. Frequency Rev. 0 | Page 6 of 12 Document Outline FEATURES GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
