Datasheet AD712 (Analog Devices) - 6
DescriptionPrecision, Low Cost, High Speed, BiFET Dual Op Amp
Pages / Page11 / 6 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/11603
File Format / SizePDF / 76 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/11603
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions Temperature, Device Limits Unit V type S = 15 V TA unless otherwise specified Min Max Frequency response section Small signal bandwidth SSBW +25C 01 3.0 MHz Full power response FPR +25C 01 200 typical kHz Slew rate SR +25C 01 16 V/s Settling time to 0.01% tS +25C 01 1.2 s Total harmonic THD +25C 01 0.0003 typical % distortion Input impedance section Differential input 4/ +25C 01 12 3 x 10 || 5.5 ||pF impedance typical Common mode input 4/ +25C 01 12 3 x 10 || 5.5 ||pF impedance typical Input voltage range section Differential input 5/ VDIN +25C 01 20 typical V voltage range Common mode 6/ V V CM +25C 01 +14.5, -11.5 voltage typical -55C to +125C -V S +VS + 4 - 2 Common mode CMRR VCM = 10 V +25C 01 76 dB rejection ratio -55C to +125C 76 VCM = 11 V +25C 70 -55C to +125C 70 Input voltage noise section Input voltage noise 0.1 Hz to 10 Hz +25C 01 2 typical Vp-p f = 10 Hz 45 typical nV / Hz f = 100 Hz 22 typical f = 1 kHz 18 typical f = 10 kHz 16 typical See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/11603
REV A PAGE 6
