Datasheet OP400 (Analog Devices)
DescriptionLow Offset, Low Power Quad Op Amp
Pages / Page12 / 1 — DLA LAND AND MARITIME. COLUMBUS, OHIO 43218-3990. STANDARD. …
File Format / SizePDF / 81 Kb
DLA LAND AND MARITIME. COLUMBUS, OHIO 43218-3990. STANDARD. http://www.landandmaritime.dla.mil. MICROCIRCUIT. DRAWING. 5962-87771
Datasheet OP400 Analog Devices
REVISIONS LTR DESCRIPTION DATE (YR-MO-DA) APPROVED Change to one part-one number format. Add table III. Editorial changes A 91-12-11 M. A. FRYE throughout. Make changes to Slew rate test as specified under Table I. B 94-12-21 M. A. FRYE Changes in accordance with NOR 5962-R049-95. Add case outline K. Table I, slew rate test, in the conditions column delete C “VIN = ±5.0 V” and “measured at VOUT = ±2.5 V”. Table IIA, group C end-point 96-11-26 R. MONNIN parameters; for device class V add “1,2,3,4,5,6,7,8 2/”. Changes in accordance with NOR 5962-R035-97. Removed table III, burn-in, dynamic burn-in, static and dynamic test circuits. D 02-12-17 R. MONNIN Drawing updated to reflect current requirements. -rrp E Update boilerplate paragraphs to current MIL-PRF-38535 requirements. -rrp 10-03-02 C. SAFFLE Deleted appendix A. Added paragraph 6.7 PIN supersession information. F 16-12-19 C. SAFFLE Update drawing to current MIL-PRF-38535 requirements. - rrp G Add radiation hardened requirements for device type 01. - ro 17-03-24 C. SAFFLE REV SHEET REV SHEET REV STATUS REV G G G G G G G G G G G OF SHEETS SHEET 1 2 3 4 5 6 7 8 9 10 11 PMIC N/A PREPARED BY MARCIA B. KELLEHER
DLA LAND AND MARITIME COLUMBUS, OHIO 43218-3990 STANDARD
CHECKED BY
http://www.landandmaritime.dla.mil MICROCIRCUIT
D. A. DiCENZO
DRAWING
APPROVED BY THIS DRAWING IS AVAILABLE MICHAEL A. FRYE MICROCIRCUIT, LINEAR, QUAD LOW OFFSET, FOR USE BY ALL DEPARTMENTS LOW POWER, OPERATIONAL AMPLIFIER, AND AGENCIES OF THE DRAWING APPROVAL DATE MONOLITHIC SILICON DEPARTMENT OF DEFENSE 87-12-11 REVISION LEVEL SIZE CAGE CODE AMSC N/A
5962-87771
G A
67268
SHEET 1 OF 11 DSCC FORM 2233 APR 97 5962-E244-17 DISTRIBUTION STATEMENT A. Approved for public release. Distribution is unlimited.
