Datasheet SRA (Songle Relay)
ManufacturerSongle Relay
DescriptionSUBMINATURE HIGH POWER RELAY 10A/20A
Pages / Page2 / 1 — SRA. Series. SUBMINATURE. HIGH. POWER. RELAY. 10A/20A. 16MAX. X. A. …
File Format / SizePDF / 3.6 Mb
SRA. Series. SUBMINATURE. HIGH. POWER. RELAY. 10A/20A. 16MAX. X. A. Features. C. US. 12.4M. E167996. ·Miniature. volume,. PCB. usage. X. A. M. ·Contact
Datasheet SRA Songle Relay
SRA Series SUBMINATURE HIGH POWER RELAY 10A/20A 16MAX X A Features C US 12.4M E167996 ·Miniature volume, PCB usage X A M ·Contact rating:10A/20A .2 4 1 ·Temperature range:-40 / ℃ 8 + 5℃ Ordering Information Contact Rating SRA-12VDC-C L Contact a rrangment A / B / C Contact resistance 100mΩ(1A 6VDC) Contact material Silver alloy:AgCdO、AgSnO2、AgNi Contact rating 20A/14VAC 10A/125VAC L0.60W / D0.80W Coil Power Max switching voltage 125VAC A / C Contact arrangment Max switching current 10A 3V / 5V / 6V / 9V 12V / 18V / 24V Max switching power 1250VA Coil Voltage Electrical endurance (frequency: 1800 ops/h) 1x10 5ops / 1x10 4ops Part number 7 endurance Mechanical 1x10 ops (frequency: 18000 ops/h) Characteristics Coil Data ( 20 at ℃) Insulation system B / F Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 100MΩ (500VDC) W VDC mA ± Ω 10% voltage voltage allowable Dielectric Between contacts 1500VAC 1 minute 03 200 15 Strength and coil Leakage current Between open 05 120 42 500VAC 1 minute 1mA contacts 06 100 60 Operate time(Under nominal voltage) ≤10ms 0.60W 09 66.7 135 75%Max 10%Min 110% Release time(Under nominal voltage) ≤10ms ( L ) 12 50 240 Humidity 45% ~85% RH(20℃) 18 33 540 - Ambient Temperature 40℃~+85℃ 24 25 960 03 267 11.25 Functional 98m/s
²
Shock 05 160 31.25 resistance Destructive 980m/s
²
06 133.4 45 Vibration resistance 10Hz
55Hz 1
5mm ( Double amplitude) 0.80W 09 100 90 75%Max 10%Min 110% Approx 6g Weight ( D ) 12 66.7 180 Sealed 18 44.4 405 Construction 24 33.4 720 Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2
