SLA Series SUBMINATURE HIGH POWER RELAY 4P 16A/20A/30A C US 3 Features 2M AX AX E179944 27.6M X A ·Miniature volume, PCB usage M .4 0 ·Contact rating:16A/20A/30A 2 · R50056114 Dielectric voltage choice: 2000V/4000V ·Temperature range:+85℃/+105℃ CQC CQC08002027666 CQC08002027668 Ordering Information Contact Rating SLA-12VDC-S L-C Contact a rrangment A / B / C Contact resistance 100mΩ A / B / C Contact material Silver alloy:AgCdO、AgSnO2、AgNi Contact arrangment Contact rating 1HP/16A/120VAC 20A/250VAC 30A/250VAC L0.9W Coil Power Max switching voltage 250VAC S sealed / F dustproof Construction Max switching current 30A 5V / 6V / 9V / 12V 18V / 24V/36V/48V Max switching power 7200VA Coil Voltage Electrical endurance (frequency: 1800 ops/h) 1x10 5ops / 1x10 4ops Part number 7 endurance Mechanical 1x10 ops (frequency: 18000 ops/h) Characteristics Coil Data ( 20 at ℃) Insulation system B / F Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 100MΩ (500VDC) W VDC mA ± Ω 10% voltage voltage allowable nim Dielectric Between contacts 2000/4000VAC minute 1 Strength and coil 05 185 27 Leakage current Between open 1000VAC 1 minute 1mA contacts 06 150 40 Operate time(Under nominal voltage) ≤10ms Release time(Under nominal voltage) ≤10ms 09 100 90 Humidity 45% ~85% RH(20℃) 12 75 160 Ambient Temperature - 0.9W 40℃~+85℃/-40℃~+105℃ 75%Max 10%Min 130% ( L ) Functional 98m/s ² Shock 18 50 380 resistance Destructive 980m/s ² 24 37.5 640 Vibration resistance 10Hz ~ 55Hz 1 . 5mm ( Double amplitude) Weight Approx 23g 36 25 1440 Sealed Construction 48 18.75 2560 Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2
