Datasheet SMI-1P (Songle Relay)
ManufacturerSongle Relay
DescriptionSubminature High Power Relay 10A
Pages / Page2 / 1 — SMI-1P. Series. SUBMINATURE. HIGH. POWER. RELAY. 10A. Features. C. US. …
File Format / SizePDF / 3.6 Mb
SMI-1P. Series. SUBMINATURE. HIGH. POWER. RELAY. 10A. Features. C. US. AX. 29.2MAX. 13M. E167996. X. ·Miniature. volume,. PCB. usage. A. M. .6. ·Contact. rating:10A. 0
Datasheet SMI-1P Songle Relay
SMI-1P Series SUBMINATURE HIGH POWER RELAY 10A Features C US AX 29.2MAX 13M E167996 X ·Miniature volume, PCB usage A M .6 ·Contact rating:10A 0 2 ·Temperature range: -40℃/+85℃ R50056114 ·Creepage distance 6mm can reach the enhanced insulation standard Ordering Information Contact Rating SMI-12VDC-S L-C Contact a rrangment A / B / C Contact resistance 100mΩ A / B / C Contact material Silver alloy:AgCdO、AgSnO2、AgNi Contact arrangment Contact rating 10A/240VAC 10A/250VAC L0.54W / D0.72W Coil Power Max switching voltage 250VAC S sealed / F dustproof Construction Max switching current 10A 5V / 6V / 9V 12V / 18V / 24V / 36V / 48V Max switching power 2500VA Coil Voltage Electrical endurance (frequency: 1800 ops/h) 1x10 5ops / 1x10 4 ops Part number 7 endurance Mechanical 1x10 ops (frequency: 18000 ops/h) Characteristics Coil Data ( 20 at ℃) Insulation system B / F Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 100MΩ (500VDC) W VDC mA ± Ω 10% voltage voltage allowable Dielectric Between contacts 5000VAC 1 minute 05 144 34. 7 Strength and coil 06 120 50 Leakage current Between open 1000VAC 1 minute 1mA contacts 09 80 112. 5 Operate time(Under nominal voltage) ≤10ms 12 60 200 0.54W 75%Max 5%Min 130% 18 40 450 Release time(Under nominal voltage) ≤10ms ( L ) 24 30 800 Humidity 45% ~85% RH(20℃) 36 20 1800 Ambient Temperature -40℃~+85℃ 48 15 3200 05 108 46. 3 Functional 98m/s
²
Shock 06 90 66. 7 resistance Destructive 980m/s
²
09 60 150 Vibration resistance 12 45 267 10Hz
55Hz 1
5mm ( Double amplitude) 0.72W 18 75%Max 5%Min 130% 30 600 1 Approx 5g Weight ( D ) 24 22. 5 1067 Sealed 36 15 2400 Construction 48 11. 2 4267 Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2
