Datasheet BGA Package 221-Lead (15mm×11.25mm ×2.82mm) (Linear Technology)
ManufacturerLinear Technology
DescriptionReference LTC DWG# 05-08-1886
Pages / Page1 / 1 — BGA Package. 221-Lead (15mm. 11.25mm. 2.82mm). DIMENSIONS. SYMBOL. MIN. …
RevisionC
File Format / SizePDF / 265 Kb
BGA Package. 221-Lead (15mm. 11.25mm. 2.82mm). DIMENSIONS. SYMBOL. MIN. NOM. MAX. NOTES
Datasheet BGA Package 221-Lead (15mm×11.25mm ×2.82mm) Linear Technology, Revision: C
BGA
11.25mm
2.82mm)
(Reference LTC DWG# 05-08-1886 Rev C) A Z SEE NOTES DETAIL A aaa Z E Y 7 X A2 SEE NOTES 13 12 11 10 9 8 7 6 5 4 3 2 1 PIN 1 3 Z A A1 PIN “A1” B ccc Z CORNER C 4 b D E b1 MOLD F CAP SUBSTRATE G H1 H H2 D F J DETAIL B // bbb Z K L M Øb (221 PLACES) e N ddd M Z X Y eee M Z P Q R S aaa Z e b PACKAGE TOP VIEW DETAIL A G DETAIL B PACKAGE BOTTOM VIEW 4.25 3.75 PACKAGE SIDE VIEW NOTES: 4.80 4.00 3.20 2.40 1.60 0.80 0.00 0.80 1.60 2.40 3.20 4.00 4.80 1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M-1994 0.40 ±0.025 Ø 221x 6.40 2. ALL DIMENSIONS ARE IN MILLIMETERS
DIMENSIONS
5.60 BALL DESIGNA 3 TION PER JESD MS-028 AND JEP95
SYMBOL MIN NOM MAX NOTES
4.80 A 2.67 2.82 2.97 4 DETAILS OF PIN #1 IDENTIFIER ARE OPTIONAL, BUT MUST BE LOCATED WITHIN THE ZONE INDICATED. 4.00 A1 0.35 0.40 0.45 BALL HT THE PIN #1 IDENTIFIER MAY BE EITHER A MOLD OR A2 2.32 2.42 2.52 3.20 MARKED FEATURE b 0.45 0.50 0.55 BALL DIMENSION 2.40 5. PRIMARY DATUM -Z- IS SEATING PLANE b1 0.37 0.40 0.43 PAD DIMENSION 1.60 D 15.0 6 PACKAGE ROW AND COLUMN LABELING MAY VARY
AMONG µModule PRODUCTS. REVIEW EACH PACKAGE 0.80 E 11.25 LAYOUT CAREFULLY e 0.80 0.00 F 12.80 0.80 G 9.60 1.60 H1 0.37 0.42 0.47 SUBSTRATE THK 2.40 H2 1.95 2.00 2.05 MOLD CAP HT aaa 0.15 3.20 bbb 0.10 LTMXXXXXX 4.00 ccc 0.12 µModule 4.80 ddd 0.15 COMPONENT 5.35 eee 0.08 PIN “A1” 5.60 5.85 TOTAL NUMBER OF BALLS: 221 6.40 TRAY PIN 1 BEVEL SUGGESTED PCB LAYOUT PACKAGE IN TRAY LOADING ORIENTATION BGA 221 0517 REV C TOP VIEW
