Datasheet TPS2410, TPS2411 (Texas Instruments) - 2
Manufacturer | Texas Instruments |
Description | Full Feaured N+1 and ORing Power Rail Controller |
Pages / Page | 32 / 2 — TPS2410. TPS2411. www.ti.com. ORDERING INFORMATION(1). DEVICE. … |
Revision | C |
File Format / Size | PDF / 1.4 Mb |
TPS2410. TPS2411. www.ti.com. ORDERING INFORMATION(1). DEVICE. TEMPERATURE. PACKAGE(2). ORDERING CODE. MARKING
TPS2410 TPS2411
SLVS727C – NOVEMBER 2006 – REVISED JUNE 2009 ..
www.ti.com
This integrated circuit can be damaged by ESD. Texas Instruments recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications.
ORDERING INFORMATION(1) DEVICE TEMPERATURE PACKAGE(2) ORDERING CODE MARKING
TPS2410 TPS2410PW TPS2410 –40°C to 85°C PW (TSSOP-14) TPS2411 TPS2411PW TPS2411 (1) Add an R suffix to the device type for tape and reel. (2) For the most current package and ordering information, see the Package Option Addendum at the end of this document, or see the TI website at www.ti.com.
ABSOLUTE MAXIMUM RATINGS(1)
over operating free-air temperature range, voltage are referenced to GND (unless otherwise noted)
VALUE UNIT
A, C, FLTR, VDD, STAT voltage –0.3 to 18 V A above C voltage(2) 7.5 V C above A voltage 18 V GATE(3), BYP voltage –0.3 to 30 V BYP(3) to A voltage –0.3 to 13 V GATE above BYP voltage 0.3 V FLTR(3) to C voltage –0.3 to 0.3 V OV, UV voltage –0.3 to 5.5 V RSET voltage(3) –0.3 to 7 V FLTB, PG voltage –0.3 to 18 V STAT, PG, FLTB sink current 40 mA GATE short to A or C or GND Indefinite Human body model 2 kV ESD Charged device model 500 V TJ Maximum junction temperature Internally limited °C Tstg Storage temperature –65 to 150 °C (1) Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under recommended operating conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. (2) See the section "Bidirectional Blocking and Protection of C." (3) Voltage should not be applied to these pins.
DISSIPATION RATINGS POWER RATING PACKAGE
θ
JA – Low k °C/W
θ
JA – High k °C/W High k TA = 85°C (mW)
PW (TSSOP) 173 99 404 2 Submit Documentation Feedback Copyright © 2006–2009, Texas Instruments Incorporated Product Folder Link(s): TPS2410 TPS2411 Document Outline FEATURES APPLICATIONS DESCRIPTION ABSOLUTE MAXIMUM RATINGS DISSIPATION RATINGS RECOMMENDED OPERATING CONDITIONS ELECTRICAL CHARACTERISTICS: TPS2410/11 DETAILED DESCRIPTION TYPICAL CHARACTERISTICS APPLICATION INFORMATION OVERVIEW TPS2410 vs TPS2411 – MOSFET CONTROL METHODS N+1 POWER SUPPLY – TYPICAL CONNECTION INPUT ORing – TYPICAL CONNECTION SYSTEM DESIGN AND BEHAVIOR WITH TRANSIENTS RECOMMENDED OPERATING RANGE TPS2410 REGULATION-LOOP STABILITY MOSFET SELECTION AND R(RSET) GATE DRIVE, CHARGE PUMP AND C(BYP) FAST COMPARATOR INPUT FILTERING – C(FLTR) UV, OV, AND PG VDD, BYP, and POWERING OPTIONS INPUT ORing AND STAT BIDIRECTIONAL BLOCKING AND PROTECTION OF C ORing EXAMPLES SUMMARIZED DESIGN PROCEDURE Layout Considerations
