Datasheet RH111 (Analog Devices)
DescriptionVoltage Comparator
Pages / Page4 / 1 — DESCRIPTIO. ABSOLUTE. AXI U. R TI GS. U U. BUR -I CIRCUIT. PACKAGE/ORDER …
File Format / SizePDF / 60 Kb
DESCRIPTIO. ABSOLUTE. AXI U. R TI GS. U U. BUR -I CIRCUIT. PACKAGE/ORDER I FOR ATIO
Datasheet RH111 Analog Devices
RH111 Voltage Comparator
U W W W U DESCRIPTIO ABSOLUTE AXI U A R TI GS
The RH111 is a general purpose voltage comparator. The Supply Voltage (Pin 8 to Pin 4) ... 36V RH111 offers maximum input offset voltage of 3mV and Output to Negative Supply (Pin 7 to Pin 4) .. 35V input offset current of 10nA with a typical response time Ground to Negative Supply (Pin 1 to Pin 4) ... 30V of 200ns. The RH111 can operate from a single 5V supply Differential Input Voltage ... 35V to ±15V supplies and can drive up to 50mA loads referred Voltage at Strobe Pin (Pin 6 to Pin 8) .. 5V to ground or either supply. A separate output Ground pin Input Voltage (Note 1) ... ±15V allows output signals to be isolated from analog ground. Output Short-Circuit Duration ... 10 sec Operating Temperature The wafer lots are processed to the requirements of Range (Note 2) .. – 55°C to 125°C Linear Technology's in-house Class S flow to yield circuits Storage Temperature Range ... – 65°C to 150°C usable in precision space applications. Lead Temperature (Soldering, 10 sec).. 300°C , LTC and LT are registered trademarks of Linear Technology Corporation.
U U BUR -I CIRCUIT
18V 15V 1.3k 8 100k 8 50k 3 2 50k 2V – + 5 OR 7 7 200Ω 2 50k 3 + 1 – 1 4 4 604Ω –18V RH111 BI01 –15V RH111 BI02
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW V+ TOP VIEW TOP VIEW 8 GND 1 7 OUT GND 1 10 V+ GND 1 8 V+ +IN 2 9 OUTPUT + BALANCE/ +IN 2 6 +IN 2 7 OUT – STROBE –IN 3 8 NC BALANCE/ –IN 3 6 STROBE NC 4 7 BAL/STROBE –IN 3 5 BALANCE 4 V – 4 5 BALANCE V–– 5 6 BAL V– H PACKAGE J8 PACKAGE W PACKAGE 8-LEAD TO-5 METAL CAN 8-LEAD CERDIP 10-LEAD CERPAC 1
