Datasheet LTC1863L, LTC1867L (Analog Devices) - 3
DescriptionMicropower, 3V, 16-Bit, 8-Channel 175ksps ADCs
Pages / Page16 / 3 — CONVERTER CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 256 Kb
CONVERTER CHARACTERISTICS. The. denotes the specifications which apply over the full operating
CONVERTER CHARACTERISTICS The denotes the specifications which apply over the full operating
LTC1863L/LTC1867L
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VDD = 2.7V, external VREF = 1.25V (Notes 5, 6) LTC1863L LTC1867L LTC1867LA PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
Gain Error Unipolar ±6 ±96 ±64 LSB Bipolar ±6 ±96 ±64 LSB Gain Error Match Unipolar ±1 ±4 ±3 LSB Bipolar ±1 ±4 ±3 LSB Gain Error Tempco Internal Reference ±20 ±20 ±20 ppm/°C External Reference ±3 ±3 ±3 ppm/°C Power Supply Sensitivity VDD = 2.7V – 3.6V ±1 ±3 ±3 LSB
DYNAMIC ACCURACY VDD = 3V, external VREF = 1.25V (Note 5) LTC1863L LTC1867L/LTC1867LA SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 1kHz Input Signal 73.1 83.7 dB S/(N+D) Signal-to-(Noise + Distortion) Ratio 1kHz Input Signal 73 83.1 dB THD Total Harmonic Distortion 1kHz Input Signal, Up to 5th Harmonic –91.8 – 92.3 dB Peak Harmonic or Spurious Noise 1kHz Input Signal –94.8 –95.1 dB Channel-to-Channel Isolation 100kHz Input Signal –100 –112 dB Full Power Bandwidth –3dB Point 1.25 1.25 MHz
ANALOG INPUT The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) LTC1863L/LTC1867L/LTC1867LA SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Analog Input Range Unipolar Mode (Note 9) l 0 to 2.5 V Bipolar Mode l ±1.25 V CIN Analog Input Capacitance for CH0 to Between Conversions (Sample Mode) 32 pF CH7/COM During Conversions (Hold Mode) 4 pF tACQ Sample-and-Hold Acquisition Time l 2.01 1.68 µs Input Leakage Current On Channels, CHX = 0V or VDD l ±1 µA
INTERNAL REFERENCE CHARACTERISTICS (Note 5) LTC1863L/LTC1867L/LTC1867LA PARAMETER CONDITIONS MIN TYP MAX UNITS
VREF Output Voltage IOUT = 0 1.235 1.25 1.265 V VREF Output Tempco IOUT = 0 ±20 ppm/°C VREF Line Regulation 2.7V ≤ VDD ≤ 3.6V 0.3 mV/V VREF Output Resistance IOUT  ≤0.1mA 3 kΩ REFCOMP Output Voltage IOUT = 0 2.5 V
DIGITAL INPUTS AND DIGITAL OUTPUTS The
VIH High Level Input Voltage VDD = 3.6V l 1.9 V VIL Low Level Input Voltage VDD = 2.7V l 0.45 V 1863l7lfe For more information www.linear.com/LTC1863L 3 Document Outline Description Absolute Maximum Ratings Pin Configuration Typical Performance Characteristics Pin Functions Package Description Related Parts
