Datasheet RH3083MK DICE/DWF (Analog Devices) - 6
Description | Adjustable 2.8A Single Resistor Low Dropout Regulator |
Pages / Page | 6 / 6 — tyPical PerForMance characteristics. SET Pin Current. Offset Voltage. … |
File Format / Size | PDF / 249 Kb |
tyPical PerForMance characteristics. SET Pin Current. Offset Voltage. Minimum Load Current. Dropout Voltage. (Minimum IN Voltage)
RH3083MK DICE/DWF
tyPical PerForMance characteristics SET Pin Current Offset Voltage Minimum Load Current
50.5 1.0 1.0 IL = 1mA 50.4 0.8 0.9 50.3 0.6 0.8 50.2 0.4 0.7 50.1 0.2 0.6 VIN – VOUT = 23V, VCONTROL – VOUT = 25V 50.0 0 0.5 V 49.9 –0.2 0.4 IN – VOUT = 1V, VCONTROL – VOUT = 2V 49.8 –0.4 0.3 SET PIN CURRENT (µA) OFFSET VOLTAGE (mV) 49.7 –0.6 MINIMUM LOAD CURRENT (mA) 0.2 49.6 –0.8 0.1 49.5 –1.0 0 0 50 100 150 200 0 50 100 150 200 0 50 100 150 200 TOTAL DOSE (kRADS) TOTAL DOSE (kRADS) TOTAL DOSE (kRADS) 3083 G01 3083 G02 3083 G03
Dropout Voltage Dropout Voltage (Minimum IN Voltage) (Minimum VCONTROL Pin Voltage) Current Limit
500 1.4 4.0 ILOAD = 2.8A V 450 3.8 IN = VCONTROL = 5V V 1.2 OUT = 0V ) (mV) 400 3.6 OUT 350 1.0 3.4 -V ) (V) IN 300 3.2 OUT 0.8 250 -V 3.0 200 0.6 2.8 ILOAD = 1A CONTROL 150 (V 0.4 CURRENT LIMIT (A) 2.6 100 2.4 MINIMUM VOLTAGE (V 0.2 50 MINIMUM VCONTROL PIN VOLTAGE 2.2 ILOAD = 2.8A 0 0 2.0 0 50 100 150 200 0 50 100 150 200 0 50 100 150 200 TOTAL DOSE (kRADS) TOTAL DOSE (kRADS) TOTAL DOSE (kRADS) 3083 G04 3083 G05 3083 G06
revision history REV DATE DESCRIPTION PAGE NUMBER
A 10/14 IL Min = 5mA; VCONTROL = 2V to 25V; Line Reg ISET and Line Reg, VOS update, added Note 11 2, 3, 4 ID 66-13-3083 rh3083mkfa 6 LT 1014 REV A • PRINTED IN USA Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 LINEAR TECHNOLOGY CORPORATION 2014 Document Outline Features Description Dice Pinout Absolute Maximum Ratings Table 1. DICE/DWF Electrical Test Limits Table 2. Electrical Characteristics Table 3. Electrical Characteristics Table 4. Electrical Test Requirements Total Dose Bias Circuit Burn-In Circuit Typical Performance Characteristics Revision History
