Datasheet LT3741, LT3741-1 (Analog Devices) - 4
DescriptionHigh Power, Constant Current, Constant Voltage, Step-Down Controller
Pages / Page24 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 639 Kb
LT3741/LT3741-1
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN = 12V, VEN/UVLO = 5V, VSYNC = 0V unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS Current Control Loop gm Amp
Offset Voltage VCM =4V l –3 0 3 mV Input Common Mode Range VCM(LOW) 0 V VCM(HIGH) VCM(HIGH) Measured from VIN to VCM 2 V Output Impedance 3.5 MΩ gm 375 475 625 µA/V Differential Gain 1.7 V/mV
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings to 125°C operating junction temperature range are assured by design, may cause permanent damage to the device. Exposure to any Absolute characterization and correlation with statistical process controls. The Maximum Rating condition for extended periods may affect device LT3741I is guaranteed to meet performance specifications over the –40°C reliability and lifetime. to 125°C operating junction temperature range.
Note 2:
The LT3741E is guaranteed to meet performance specifications
Note 3:
The minimum on, off, and nonoverlap times are guaranteed by from 0°C to 125°C junction temperature. Specifications over the –40°C design and are not tested.
TYPICAL PERFORMANCE CHARACTERISTICS EN/UVLO Threshold (Falling) EN/UVLO Pin Current
1.70 10 1.64 8 1.58 6 –50°C 1.52 4 130°C EN/UVLO THRESHOLD (V) 1.46 EN/UVLO PIN CURRENT (µA) 2 25°C 130°C –50°C 1.40 0 6 12 18 24 30 36 6 12 18 24 30 36 VIN (V) VIN (V) 3741 G01 3741 G02
IQ in Shutdown Quiescent Current (Non-Switching)
0.5 2.0 0.4 1.6 0.3 1.2 (µA) I Q 130°C 0.2 0.8 0.1 QUIESCENT CURRENT (mA) 0.4 TA = 25°C T 25°C A = 130°C TA = –50°C 0 0 0 8 16 24 32 40 6 12 18 24 30 36 VIN (V) VIN (V) 3741 G03 3741 G04 37411fg 4 For more information www.linear.com/LT3741 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Typical Application Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
