Datasheet LT6376 (Analog Devices) - 5
Description±230V Common Mode Voltage G = 10 Difference Amplifier
Pages / Page30 / 5 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
LT6376
denotes the specifications which apply over the full operating temperature range, –40°C < TA < 85°C for I-grade parts, –40°C < TA < 125°C for H-grade parts, otherwise specifications are at TA = 25°C, V+ = 5V, V– = 0V, VCM = VOUT = VREF = Mid-Supply. VCMOP is the common mode voltage of the internal op amp. For Resistor Divider Ratio = 3.1, ±REFA = ±REFC = OPEN, ±REFB = Mid-Supply. For Resistor Divider Ratio = 8.3, ±REFA = ±REFC = Mid-Supply, ±REFB = OPEN. For Resistor Divider Ratio = 10.3, ±REFA = ±REFB = ±REFC = Mid-Supply. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
G Gain VOUT = 1V to 4V 10 V/V ∆G Gain Error, VOUT = 1V to 4V ±0.002 ±0.01 % MS16 Package l ±0.012 % ∆G Gain Error, VOUT = 1V to 4V ±0.002 ±0.012 % DF14 Package l ±0.013 % ∆G/∆T Gain Drift vs Temperature VOUT = 1V to 4V l ±0.2 ±1 ppm/°C (Note 6) GNL Gain Nonlinearity VOUT = 1V to 4V ±1 ppm VOS Input Offset Voltage 0 < VCMOP < V+ –1.75V Resistor Divider Ratio = 3.1 50 200 µV Resistor Divider Ratio = 3.1 l 600 µV Resistor Divider Ratio = 8.3 120 500 µV Resistor Divider Ratio = 8.3 l 1600 µV Resistor Divider Ratio = 10.3 160 600 µV Resistor Divider Ratio = 10.3 l 2000 µV ∆VOS/∆T Input Offset Voltage Drift 0 < VCMOP < V+ –1.75V (Note 6) Resistor Divider Ratio = 3.1 l 1.5 4 µV/°C Resistor Divider Ratio = 10.3 l 5 12 µV/°C RIN Input Impedance (Note 8) Common Mode Resistor Divider Ratio = 3.1 l 47 56 65 kΩ Resistor Divider Ratio = 8.3 l 36 43 50 kΩ Resistor Divider Ratio = 10.3 l 35 42 49 kΩ Differential l 128 152 176 kΩ CMRR Common Mode Rejection Ratio, Resistor Divider Ratio = 3.1 90 97 dB MS16 Package VCM = –5.25V to +4.825V l 87 dB Resistor Divider Ratio = 8.3 90 97 dB VCM = –18.25V to +8.725V l 87 dB Resistor Divider Ratio = 10.3 90 97 dB VCM = –23.25V to +10.225V l 87 dB CMRR Common Mode Rejection Ratio, Resistor Divider Ratio = 3.1 86 94 dB DF14 Package VCM = –5.25V to +4.825V l 85 dB Resistor Divider Ratio = 8.3 86 94 dB VCM = –18.25V to +8.725V l 85 dB Resistor Divider Ratio = 10.3 86 94 dB VCM = –23.25V to +10.225V l 85 dB PSRR Power Supply Rejection Ratio VS = ±1.65V to ±25V, VCM = VOUT = Mid-Supply (Input Referred) Resistor Divider Ratio = 3.1 l 105 120 dB Resistor Divider Ratio = 8.3 l 98 110 dB Resistor Divider Ratio = 10.3 l 96 107 dB eni Input Referred Noise Voltage f = 1kHz Density Resistor Divider Ratio = 3.1 105 nV/√Hz Resistor Divider Ratio = 10.3 245 nV/√Hz Input Referred Noise Voltage f = 0.1Hz to 10Hz Resistor Divider Ratio = 3.1 4 µV P-P Resistor Divider Ratio = 10.3 10 µVP-P VOL Output Voltage Swing Low No Load l 5 50 mV (Referred to V–) ISINK = 5mA l 280 500 mV VOH Output Voltage Swing High No Load l 5 20 mV (Referred to V+) ISOURCE = 5mA l 400 750 mV 6376f For more information www.linear.com/LT6376 5 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION E LECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS PIN FUNCTIONS BLOCK DIAGRAM APPLICATIONS INFORMATION TYPICAL APPLICATIONS PACKAGE DESCRIPTION TYPICAL APPLICATION RELATED PARTS
