Datasheet LT8391 (Linear Technology) - 4
ManufacturerLinear Technology
Description60V Synchronous 4-Switch Buck-Boost LED Controller with Spread Spectrum
Pages / Page34 / 4 — The. denotes the specifications which apply over the full operating
File Format / SizePDF / 466 Kb
The denotes the specifications which apply over the full operating
LT8391 ELECTRICAL CHARACTERISTICS
The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 2). VIN = 12V, VEN/UVLO = 1.5V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
RP Pin Current Limit VRP = 0V, Current out of Pin 40 µA Minimum VOUT for PWMTG to be On PWM dimming on 2.4 3 V PWMTG On Voltage V(VOUT-PWMTG) VOUT = 12V 4.6 5 5.4 V PWMTG Off Voltage V(VOUT-PWMTG) VOUT = 12V –0.1 0 0.1 V PWM to PWMTG Turn On Propagation Delay CPWMTG = 3.3nF to VOUT, 50% to 50% 90 ns PWM to PWMTG Turn Off Propagation Delay CPWMTG = 3.3nF to VOUT, 50% to 50% 40 ns PWMTG Turn On Fall Time CPWMTG = 3.3nF to VOUT, 10% to 90% 300 ns PWMTG Turn Off Rise Time CPWMTG = 3.3nF to VOUT, 90% to 10% 10 ns
Error Amplifier
Full Scale LED Current Regulation V(ISP-ISN) VCTRL1/2 ≥ 1.35V (Note 4), VISP = 12V l 97 100 103 mV VCTRL1/2 ≥ 1.35V (Note 4), VISP = 0V l 97 100 103 mV 9/10th LED Current Regulation V(ISP-ISN) VCTRL1/2 = 1.15V (Note 4), VISP = 12V l 87 90 93 mV VCTRL1/2 = 1.15V (Note 4), VISP = 0V l 87 90 93 mV 1/2 LED Current Regulation V(ISP-ISN) VCTRL1/2 = 0.75V (Note 4), VISP = 12V l 47.5 50 52.5 mV VCTRL1/2 = 0.75V (Note 4), VISP = 0V l 47.5 50 52.5 mV 1/20th LED Current Regulation V(ISP-ISN) VCTRL1/2 = 0.30V (Note 4), VISP = 12V l 3 5 7 mV VCTRL1/2 = 0.30V (Note 4), VISP = 0V l 3 5 7 mV Zero Scale LED Current Regulation V(ISP-ISN) VCTRL1/2 = 0.25V (Note 4), VISP = 12V l –2 0 2 mV VCTRL1/2 = 0.25V (Note 4), VISP = 0V l –2 0 2 mV ISP/ISN Input Common Mode Range l 0 60 V ISP/ISN Low Side to High Side Switchover VISP = VISN 1.8 V Voltage ISP/ISN High Side to Low Side Switchover VISP = VISN 1.7 V Voltage ISP Input Bias Current VPWM = 5V, VISP = VISN = 12V 23 µA VPWM = 5V, VISP = VISN = 0V –10 µA VEN/UVLO = 0V, VISP = VISN = 12V or 0V 0 µA ISN Input Bias Current VPWM = 5V, VISP = VISN = 12V 23 µA VPWM = 5V, VISP = VISN = 0V –10 µA VEN/UVLO = 0V, VISP = VISN = 12V or 0V 0 µA LED Current Regulation Amplifier gm 2000 µS FB Regulation Voltage VC = 1.2V l 0.98 1.00 1.02 V FB Line Regulation VIN = 4V to 60V 0.2 0.5 % FB Load Regulation 0.2 0.8 % FB Voltage Regulation Amplifier gm 660 µS FB Input Bias Current FB in Regulation, Current Out of Pin 10 40 nA VC Output Impedance 10 MΩ VC Standby Leakage Current VC = 1.2V, PWM Dimming Off –10 0 10 nA 8391fa 4 For more information www.linear.com/LT8391
