Data SheetAD420THEORY OF OPERATION The AD420 uses a sigma-delta (Σ-Δ) architecture to carry out approximately one volt remaining of drive capability (when the digital-to-analog conversion. This architecture is particularly the gate of the output PMOS transistor nearly reaches ground). well suited for the relatively low bandwidth requirements of the Thus the FAULT DETECT output activates slightly before the industrial control environment because of its inherent compliance limit is reached. Since the comparison is made monotonicity at high resolution. within the feedback loop of the output amplifier, the output In the AD420 a second order modulator is used to keep com- accuracy is maintained by its open-loop gain, and no output plexity and die size to a minimum. The single bit stream from error occurs before the fault detect output becomes active. the modulator controls a switched current source that is then The 3-wire digital interface, comprising DATA IN, CLOCK, filtered by two, continuous time resistor-capacitor sections. and LATCH, interfaces to all commonly used serial micropro- The capacitors are the only external components that have to be cessors without the addition of any external glue logic. Data is added for standard current-out operation. The filtered current loaded into an input register under control of CLOCK and is is amplified and mirrored to the supply rail so that the application loaded to the DAC when LATCH is strobed. If a user wants to simply sees a 4 mA–20 mA, 0 mA–20 mA, or 0 mA–24 mA minimize the number of galvanic isolators in an intrinsical y current source output with respect to ground. The AD420 safe application, the AD420 can be configured to run in is manufactured on a BiCMOS process that is well suited to asynchronous mode. This mode is selected by connecting the implementing low voltage digital logic with high performance LATCH pin to VCC through a current limiting resistor. The data and high voltage analog circuitry. must then be combined with a start and stop bit to frame the The AD420 can also provide a voltage output instead of a current information and trigger the internal LATCH signal. loop output if desired. The addition of a single external amplifier VCC al ows the user to obtain 0 V–5 V, 0 V–10 V, ±5 V, or ±10 V. 23VLL 2REFERENCE The AD420 has a loop fault detection circuit that warns if the 4kΩ40ΩREF OUT 14 voltage at I 19 BOOST OUT attempts to rise above the compliance range, due AD420 to an open-loop circuit or insufficient power supply voltage. The REF IN 15 FAULT DETECT is an active low open drain signal so that one DATA OUT 10CLOCK18 I can connect several AD420s together to one pul -up resistor for OUTCLEAR 6DATA I/P17 VOUT global error detection. The pul -up resistor can be tied to the LATCH 7REGISTERSWITCHED16-BITCURRENT81.25kΩ V CLOCKDAC LL pin, or an external +5 V logic supply. SOURCES9FAULTDATA INAND3DETECT The I FILTERING OUT current is controlled by a PMOS transistor and an RANGESELECT 1 5 internal amplifier as shown in the functional block diagram. RANGE 4 The internal circuitry that develops the fault output avoids SELECT 216202111 using a comparator with window limits since this would require 005 OFFSETCAP 1 CAP 2GND an actual output error before the FAULT DETECT output TRIM 00494- becomes active. Instead, the signal is generated when the Figure 5. Functional Block Diagram internal amplifier in the output stage of the AD420 has less than Rev. I | Page 9 of 16 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TIMING REQUIREMENTS THREE-WIRE INTERFACE THREE-WIRE INTERFACE FAST EDGES ON DIGITAL INPUT ASYNCHRONOUS INTERFACE TERMINOLOGY THEORY OF OPERATION APPLICATIONS INFORMATION CURRENT OUTPUT DRIVING INDUCTIVE LOADS VOLTAGE-MODE OUTPUT OPTIONAL SPAN AND ZERO TRIM THREE-WIRE INTERFACE USING MULTIPLE DACS WITH FAULT DETECT ASYNCHRONOUS INTERFACE USING OPTOCOUPLERS MICROPROCESSOR INTERFACE AD420-TO-MC68HC11 (SPI BUS) INTERFACE AD420 TO MICROWIRE INTERFACE EXTERNAL BOOST FUNCTION AD420 PROTECTION TRANSIENT VOLTAGE PROTECTION BOARD LAYOUT AND GROUNDING POWER SUPPLIES AND DECOUPLING OUTLINE DIMENSIONS ORDERING GUIDE
