Datasheet ADL5390 (Analog Devices) - 9
Description | RF/IF Vector Multiplier |
Pages / Page | 23 / 9 — Data Sheet. ADL5390. –10. FUNDAMENTAL. 1V p-p BASEBAND INPUT. –20. –30. … |
Revision | A |
File Format / Size | PDF / 653 Kb |
Data Sheet. ADL5390. –10. FUNDAMENTAL. 1V p-p BASEBAND INPUT. –20. –30. –40. –15. –50. 2ND HARMONIC. 500mV p-p BASEBAND INPUT. –60. –70. –25
Data Sheet ADL5390 0 0 –10 FUNDAMENTAL –5 1V p-p BASEBAND INPUT –20 –30 –10 –40 –15 –50 2ND HARMONIC –20 500mV p-p BASEBAND INPUT –60 –70 –25 SIDEBAND POWER (dBm) –80 3RD HARMONIC RF OUTPUT SIDEBAND POWER (dBm) –30 250mV p-p BASEBAND INPUT –90 –100
04954-015
–35
04954-018
0 100 200 300 400 500 600 700 800 900 1000 0 50 100 150 200 250 300 350 400 DIFF. BASEBAND INPUT LEVEL (mV p-p) BB FREQUENCY (MHz)
Figure 15. Baseband Harmonic Distortion, (Channel I and Channel Q), Figure 18. IQ Modulation Bandwidth vs. Baseband Magnitude RF PIN = −5 dBm, (Balun and Cable Losses Not Included)
12 15 TEMP = –40°C TEMP = +25°C 10 11 5 10 FRF = 70MHz 0 FRF = 140MHz F TEMP = +85°C RF = 380MHz F 9 –5 RF = 900MHz FRF = 2400MHz OP1dB (dBm) OP1dB (dBm) –10 8 –15 7 –20 6
04954-016
–25
04954-019
0 400 800 1200 1600 2000 2400 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 FREQUENCY (MHz) GAIN SETPOINT
Figure 16. Output 1 dB Compression Point vs. RF Frequency, Figure 19. Output 1 dB Compression vs. Gain Setpoint, RF Frequency = Temp = +85°C, +25°C, −40°C, Gain Setpoint = 1.0 70 MHz, 140 MHz, 380 MHz, 900 MHz, 2400 MHz
30 30 28 25 TEMP = –40°C 26 20 24 TEMP = +25°C 15 22 FRF = 70MHz 10 FRF = 140MHz 20 FRF = 380MHz TEMP = +85°C 5 FRF = 900MHz OIP3 (dBm) 18 OIP3 (dBm) FRF = 2400MHz 0 16 14 –5 12 –10 10
04954-017 04954-020
0 400 800 1200 1600 2000 2400 –15 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 FREQUENCY (MHz) GAIN SETPOINT
Figure 17. Output IP3 vs. RF Frequency, Temp = +85°C, +25°C, −40°C, Figure 20. Output IP3 vs. Gain Setpoint, RF Frequency = 70 MHz, 140 MHz, Gain Setpoint = 1.0 380 MHz, 900 MHz, 2400 MHz Rev. A | Page 9 of 23 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics General Structure Theory of Operation Noise and Distortion Applications Information Using the ADL5390 RF Input and Matching RF Output and Matching Driving the I-Q Baseband Gain Controls Interfacing to High Speed DACs Generalized Modulator Vector Modulator Vector Modulator Example—CDMA2000 Quadrature Modulator RF Multiplexer Evaluation Board Outline Dimensions Ordering Guide
