Datasheet HMC649ALP6E (Analog Devices) - 5
DescriptionGaAs MMIC 6-Bit Digital Phase Shifter, 3 GHz to 6 GHz
Pages / Page6 / 5 — HMC649ALP6E. GaAs MMIC 6-BIT DIGITAL. PHASE SHIFTER, 3 - 6 GHz. Outline …
File Format / SizePDF / 453 Kb
HMC649ALP6E. GaAs MMIC 6-BIT DIGITAL. PHASE SHIFTER, 3 - 6 GHz. Outline Drawing. Package Information. Pin Descriptions
HMC649ALP6E GaAs MMIC 6-BIT DIGITAL PHASE SHIFTER, 3 - 6 GHz Outline Drawing Package Information Pin Descriptions
HMC649ALP6E
v00.0415
T M L - S ITA IG S - D R E NOTES: T 1. LEAD FRAME MATERIAL: COPPER ALLOY 2. DIMENSIONS ARE IN INCHES [MILLIMETERS]. IF 3. DIMENSIONS DOES NOT INCLUDE MOLDFLASH OF 0.15mm PER SIDE H 4. DIMENSIONS DOES NOT INCLUDE MOLDFLASH OF 0.25mm PER SIDE 5. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND. E S 6. CLASSIFIED AS MOISTURE SENSITIVITY LEVEL (MSL) 1. S
Package Information
A Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] H HMC649ALP6E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL3 [1] H649A P XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX
Pin Descriptions
Pin Number Function Description Interface Schematic 1 Vdd Voltage Supply These pins and exposed ground paddle 2, 20 GND must be connected to RF/DC ground. 3 RFIN This port is DC coupled and matched to 50 Ohms. No connection required. These pins may be connected to 4 - 18, 21 N/C RF/DC ground without affecting performance. 19 RFOUT This port is DC coupled and matched to 50 Ohms. 22 - 24 BIT6, BIT5, BIT4, Control Input. See truth table 26 - 28 BIT3, BIT2, BIT1 and control voltage tables. 25 Vss Voltage Supply Informat F io o n r p furn risihcee d , d by e An lialvoe g rDy a evic n e d t s is o p belie lva e c d t e o o b rd e a e cc rursa: A te a n n a d lo reli g D able. e H v o ic weveers, I no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other nc., 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 • Fax: 978-250-3373 • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Ph e o r O ne n : 7 -l 81 i-n 3 e a 29-4t w 70 ww 0 • O .h rd iettit r o e nli.c n om
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p 3 o plic r a atiopp n S su@ p h po irtttit : Pe. hocno e m : 1-800-ANALOG-D
