Datasheet HMC642ALC5 (Analog Devices) - 4
DescriptionGaAs MMIC 6-Bit Digital Phase Shifter, 9 - 12.5 GHz
Pages / Page6 / 4 — HMC642ALC5. GaAs MMIC 6-BIT DIGITAL. PHASE SHIFTER, 9 - 12.5 GHz. Phase …
File Format / SizePDF / 467 Kb
HMC642ALC5. GaAs MMIC 6-BIT DIGITAL. PHASE SHIFTER, 9 - 12.5 GHz. Phase Error vs. State. Absolute Maximum Ratings
HMC642ALC5 GaAs MMIC 6-BIT DIGITAL PHASE SHIFTER, 9 - 12.5 GHz Phase Error vs State Absolute Maximum Ratings
HMC642ALC5
v00.0415
GaAs MMIC 6-BIT DIGITAL PHASE SHIFTER, 9 - 12.5 GHz Phase Error vs. State
20 15 ) 9.5, 10, 10.5, 11, 11.5, 12, 12.5 GHz T ees M 10 (degr R O 5 R R L - S E E 0 S A H P ITA -5 9 GHz IG -10 0 45 90 135 180 225 270 315 360
STATE (degrees) Input Power (RFIN) 29 dBm (T= +85 °C) S - D Bias Voltage Range (Vdd) -0.2 to +12.5V R
Bias Voltage & Current
Bias Voltage Range (Vss) +0.2 to -12V E Channel Temperature (Tc) 150 °C Vdd Idd T Thermal Resistance 5.0 5.6mA 190 °C/W (channel to ground paddle) IF Vss Iss Storage Temperature -65 to +150 °C H -5.0 5.6mA Operating Temperature -40 to +85 °C
Control Voltage
ESD Sensitivity (HBM) Class1A Passed 250V E S State Bias Condition S Low (0) 0 to 0.2 Vdc A High (1) Vdd ±0.2 Vdc @ 35 µA Typ. H P ELECTROSTATIC SENSITIVE DEVICE OBSERVE HANDLING PRECAUTIONS
Truth Table
Control Voltage Input Phase Shift (Degrees) Bit 1 Bit 2 Bit 3 Bit 4 Bit 5 Bit 6 RFIN - RFOUT 0 0 0 0 0 0 Reference* 1 0 0 0 0 0 5.625 0 1 0 0 0 0 11.25 0 0 1 0 0 0 22.5 0 0 0 1 0 0 45.0 0 0 0 0 1 0 90.0 0 0 0 0 0 1 180.0 1 1 1 1 1 1 354.375 Any combination of the above states will provide a phase shift approximately equal to the sum of the bits selected. *Reference corresponds to monotonic setting Informat F io o n r p furn risihcee d , d by e An lialvoe g rDy a evic n e d t s is o p belie lva e c d t e o o b rd e a e cc rursa: A te a n n a d lo reli g D able. e H v o ic weveers, I no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other nc., 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 • Fax: 978-250-3373 • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Ph e o r O ne n : 7 -l 81 i-n 3 e a 29-4t w 70 ww 0 • O .h rd iettit r o e nli.c n om license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p 3 o plic r a atiopp n S su@ p h po irtttit : Pe. hocno e m : 1-800-ANALOG-D
