Datasheet MC74VHC1GT50 (ON Semiconductor) - 3
Manufacturer | ON Semiconductor |
Description | Noninverting Buffer / CMOS Logic Level Shifter |
Pages / Page | 6 / 3 — MC74VHC1GT50. DC ELECTRICAL CHARACTERISTICS. VCC. TA = 25. −55. 125. … |
Revision | 16 |
File Format / Size | PDF / 79 Kb |
MC74VHC1GT50. DC ELECTRICAL CHARACTERISTICS. VCC. TA = 25. −55. 125. Symbol. Parameter. Test Conditions. (V). Min. Typ. Max. Unit
link to page 3
MC74VHC1GT50 DC ELECTRICAL CHARACTERISTICS VCC TA = 25
C TA
85
C −55
TA
125
C Symbol Parameter Test Conditions (V) Min Typ Max Min Max Min Max Unit
VIH Minimum 1.65 to 2.29 0.50 VCC 0.50 VCC 0.50 VCC V High−Level Input Voltage 2.3 to 2.99 0.45 VCC 0.45 VCC 0.45 VCC 3.0 1.4 1.4 1.4 4.5 2.0 2.0 2.0 5.5 2.0 2.0 2.0 VIL Maximum 1.65 to 2.29 0.10 VCC 0.10 VCC 0.10 VCC V Low−Level Input Voltage 2.3 to 2.99 0.15 VCC 0.15 VCC 0.15 VCC 3.0 0.53 0.53 0.53 4.5 0.8 0.8 0.8 5.5 0.8 0.8 0.8 VOH Minimum VIN = VIH 1.65 to 2.99 VCC − 0.1 VCC − 0.1 VCC − 0.1 V High−Level Output IOH = −50 mA 3.0 2.9 3.0 2.9 2.9 Voltage 4.5 4.4 4.5 4.4 4.4 VIN = VIH V IOH = −4 mA 3.0 2.58 2.48 2.34 IOH = −8 mA 4.5 3.94 3.80 3.66 VOL Maximum VIN = VIL 1.65 to 2.99 0.0 0.1 0.1 0.1 V Low−Level Output IOL = 50 mA 3.0 0.0 0.1 0.1 0.1 Voltage 4.5 0.1 0.1 0.1 VIN = VIL V IOL = 4 mA 3.0 0.36 0.44 0.52 IOL = 8 mA 4.5 0.36 0.44 0.52 IIN Maximum VIN = 5.5 V or GND 0 to $0.1 $1.0 $1.0 mA Input 5.5 Leakage Current ICC Maximum VIN = VCC or GND 5.5 1.0 20 40 mA Quiescent Supply Current ICCT Quiescent Input: VIN = 3.4 V 5.5 1.35 1.50 1.65 mA Supply Current IOPD Output VOUT = 5.5 V 0.0 0.5 5.0 10 mA Leakage Current ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
AC ELECTRICAL CHARACTERISTICS
Cload = 50 pF, Input tr = tf = 3.0 ns ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ
TA = 25
C
ÎÎÎÎ
TA
85
C
ÎÎÎÎÎÎ
−55
TA
125
C
ÎÎ ÎÎÎÎ
Symbol
ÎÎÎÎÎÎ
Parameter
ÎÎÎÎÎÎÎÎÎÎ
Test Conditions
ÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎ ÎÎ
Min
ÎÎÎ
Typ
ÎÎÎ
Max
ÎÎ
Min
ÎÎÎ
Max
ÎÎÎ
Min Max Unit
ÎÎÎÎ ÎÎÎÎ ÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎ ÎÎÎ ÎÎÎ ÎÎÎ ÎÎ ÎÎÎ ÎÎÎ ÎÎ ÎÎÎÎ tPLH, Maximum VCC = 1.8 ± 0.15 V CL = 15 pF 16.6 18.0 22.0 ns tPHL Propagation Delay, Input A to Y VCC = 2.5 ± 0.2 V CL = 15 pF 13.3 14.5 17.5 ns CL = 50 pF 19.5 22.0 25.5 VCC = 3.3 ± 0.3 V CL = 15 pF 4.5 10.0 11.0 13.0 ns CL = 50 pF 6.3 13.5 15.0 17.5 VCC = 5.0 ± 0.5 V CL = 15 pF 3.5 6.7 7.5 8.5 CL = 50 pF 4.3 7.7 8.5 9.5 CIN Maximum Input 5 10 10 10 pF Capacitance
Typical @ 25
C, VCC = 5.0 V
C 12 PD Power Dissipation Capacitance (Note 5) pF 5. CPD is defined as the value of the internal equivalent capacitance which is calculated from the operating current consumption without load. Average operating current can be obtained by the equation: ICC(OPR) = CPD VCC fin + ICC. CPD is used to determine the no−load dynamic power consumption; P 2 D = CPD VCC fin + ICC VCC.
www.onsemi.com 3
