Datasheet HMC394LP4, 394LP4E (Analog Devices) - 4
DescriptionGaAs HBT PROGRAMMABLE 5-BIT COUNTER, DC - 2.2 GHz
Pages / Page10 / 4 — HMC394LP4 / 394LP4E. GaAs HBT PROGRAMMABLE. 5-BIT COUNTER, DC - 2.2 GHz. …
File Format / SizePDF / 591 Kb
HMC394LP4 / 394LP4E. GaAs HBT PROGRAMMABLE. 5-BIT COUNTER, DC - 2.2 GHz. Absolute Maximum Ratings. Outline Drawing
HMC394LP4 / 394LP4E GaAs HBT PROGRAMMABLE 5-BIT COUNTER, DC - 2.2 GHz Absolute Maximum Ratings Outline Drawing
HMC394LP4 / 394LP4E
v09.0114
4 RF Input (Vcc = +5V) +13 dBm Vcc +5.5V ELECTROSTATIC SENSITIVE DEVICE VLogic -1.6 to -1.2 Vcc 4 OBSERVE HANDLING PRECAUTIONS Maximum Channel Temperature 135 °C t Continuous Pdiss (T = 85 °C) (derate 55 mW/°C above 85 °C) 1.155 W t M M s Thermal Resistance (u j-c ) Junction to 21.5 °C/W Case (Ground Paddle) s s - Storage Temperature -65 to +150°C s - r Operating Temperature +55 to +85°C r o o t
Outline Drawing
t c c e e t t e e s & D s & D r r e e iD iD iv iv y D y D c c n n e NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY e u 2. DIMENSIONS ARE IN INCHES [MILLIMETERS] u q 3. LEAD SPACING TOLERANCE IS NON-CUMULATIVE. q e 4. PAD BURR LENGTH SHALL BE 0.15mm MAXIMUM. PAD BURR HEIGHT SHALL BE 0.05mm MAXIMUM. e r 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. r F 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE F SOLDERED TO PCB RF GROUND. 7. REFER TO HITTITE APPLICATION NOTE FOR SUGGESTED LAND PATTERN.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [3] HMC394LP4 Low Stress Injection Molded Plastic Sn/Pb Solder MSL1 [1] H394 XXXX HMC394LP4E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL1 [2] H394 XXXX [1] Max peak reflow temperature of 235 °C [2] Max peak reflow temperature of 260 °C [3] 4-Digit lot number XXXX Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4 - 4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
