Datasheet HMC361 (Analog Devices) - 2
DescriptionGaAs HBT MMIC DIVIDE-BY-2, DC - 11 GHz
Pages / Page6 / 2 — HMC361. GaAs HBT MMIC. DIVIDE-BY-2, DC - 11 GHz. Input Sensitivity …
File Format / SizePDF / 297 Kb
HMC361. GaAs HBT MMIC. DIVIDE-BY-2, DC - 11 GHz. Input Sensitivity Window, T= 25 °C. Input Sensitivity Window vs. Temperature
HMC361 GaAs HBT MMIC DIVIDE-BY-2, DC - 11 GHz Input Sensitivity Window, T= 25 °C Input Sensitivity Window vs Temperature
HMC361
v07.0109
1
Input Sensitivity Window, T= 25 °C Input Sensitivity Window vs. Temperature
20 20 IP 10 10 H 0
Recommended
0 Min Pin +25 C Max Pin +25 C
Operating Window
Min Pin +85 C -10 -10 Max Pin +85 C S - C Min Pin -55 C Max Pin -55 C R INPUT POWER (dBm) INPUT POWER (dBm) -20 -20 E ID -30 -30 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 IV INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) Y D
SSB Phase Noise Output Power vs. Temperature Performance, Pin= 0 dBm, T= 25 °C
NC 10 0 E 8 U -20 6 Q -40 4 E -60 2 R 0 -80 F -2 -100 -4 +25 C +85 C -120 OUTPUT POWER (dBm) -6 -55 C SSB PHASE NOISE (dBc/Hz) -140 -8 -10 -160 0 3 6 9 12 15 102 103 104 105 106 107 INPUT FREQUENCY (GHz) OFFSET FREQUENCY (Hz)
Output Harmonic Content, Pin= 0 dBm, T= 25 °C Reverse Leakage, Pin= 0 dBm, T= 25 °C
0 0 -10 Pfeedthru -10 Both Output Ports Terminated 3rd Harmonic One Output Port Terminated -20 -20 -30 -30 OUTPUT LEVEL (dBm) POWER LEVEL (dBm) -40 -40 -50 -50 0 3 6 9 12 15 0 3 6 9 12 15 INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
1 - 3
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
