Datasheet LT3573 (Analog Devices) - 3
DescriptionIsolated Flyback Converter without an Opto-Coupler
Pages / Page26 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 282 Kb
LT3573
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN = 12V, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Error Amplifier Voltage Gain VIN = 3V 150 V/V Error Amplifier Transconductance DI = 10µA, VIN = 3V 150 µmhos Minimum Switching Frequency VC = 0.35V 40 kHz TC Current into RREF RTC = 20.1k 27.5 µA BIAS Pin Voltage IBIAS = 30mA 2.9 3 3.1 V
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings to 125°C operating junction temperature range are assured by design may cause permanent damage to the device. Exposure to any Absolute characterization and correlation with statistical process controls. The Maximum Rating condition for extended periods may affect device LT3573I is guaranteed over the full –40°C to 125°C operating junction reliability and lifetime. temperature range.
Note 2:
The LT3573E is guaranteed to meet performance specifications
Note 3:
Current flows out of the RREF pin. from 0°C to 125°C junction temperature. Specifications over the –40°C
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Output Voltage Quiescent Current Bias Pin Voltage
5.20 7 3.2 VIN = 40V 5.15 6 VIN = 40V 3.0 VIN = 12V 5.10 5 2.8 5.05 4 (V) VIN = 5V 5.00 (mA) 2.6 V OUT I Q 3 4.95 BIAS VOLTAGE (V) 2.4 2 4.90 2.2 4.85 1 4.80 0 2.0 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3573 G01 3573 G02 3573 G03 3573fd For more information www.linear.com/LT3573 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
