Datasheet LTC3783 (Analog Devices) - 4
DescriptionPWM LED Driver and Boost, Flyback and SEPIC Controller
Pages / Page24 / 4 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 311 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating temperature
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the full operating temperature
LTC3783
denotes the specifications which apply over the full operating temperature range, otherwise specifications are TA = 25°C. VIN = 12V, VRUN = 1.5V, VSYNC = 0V, VFBP = VREF, RT = 20k, unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
RSYNC SYNC Input Pull-Down Resistance 100 kΩ tON(MIN) Minimum On-Time With Sense Resistor, 10mV Overdrive 170 ns No RSENSE Mode 300 ns
Low Dropout Regulator
VINTVCC INTVCC Regulator Output Voltage VOV/FB = 1.5V l 6.5 7 7.5 V UVLO INTVCC Undervoltage Lockout Rising INTVCC 2.3 2.5 V Thresholds Falling INTVCC 1.8 2.1 V Hysteresis 0.2 V ∆VINTVCC INTVCC Line Regulation 12V ≤ VIN ≤ 36V 2 6 mV/V ∆VIN ∆VLDO(LOAD) INTVCC Load Regulation 0 ≤ IINTVCC ≤ 10mA –1 –0.1 % VDROPOUT INTVCC Dropout Voltage VIN = 7V, IINTVCC = 10mA 300 500 mV IINTVCC(SD) Bootstrap Mode INTVCC Supply VSENSE = 0V 25 µA Current in Shutdown VSENSE = 7V 15 µA
GATE/PWMOUT Drivers
tr(GATE) GATE Driver Output Rise Time CL = 3300pF (Note 7) 15 ns tf(GATE) GATE Driver Output Fall Time CL = 3300pF (Note 7) 8 ns IPK(GATE,RISE) GATE Driver Peak Current Sourcing VGATE = 0V 0.5 A IPK(GATE,FALL) GATE Driver Peak Current Sinking VGATE = 7V 1 A VPWMIN PWMIN Pin Input Threshold Voltages Rising PWMIN 1.6 V Falling PWMIN 0.8 V Hysteresis 0.8 V RPWMIN PWMIN Input Pull-Up Resistance 100 kΩ tr(PWMOUT) PWMOUT Driver Output Rise Time CL = 3300pF (Note 7) 30 ns tf(PWMOUT) PWMOUT Driver Output Fall Time CL = 3300pF (Note 7) 16 ns IPK(PWMOUT,RISE) PWMOUT Driver Peak Current Sourcing VPWMOUT = 0V 0.25 A IPK(PWMOUT,FALL) PWMOUT Driver Peak Current Sinking VPWMOUT = 7V 0.50 A
Note 1:
Note 4:
The dynamic input supply current is higher due to power MOSFET may cause permanent damage to the device. Exposure to any Absolute gate charging (QG • fOSC). See Operation section. Maximum Rating condition for extended periods may affect device
Note 5:
The LTC3783 is tested in a feedback loop which servos VFBN to reliability and lifetime. VFBP = VVREF with the ITH pin forced to the midpoint of its voltage range
Note 2:
The LTC3783E is guaranteed to meet performance specifications (0.3V ≤ VITH ≤ 1.2V; midpoint = 0.75V). over the 0°C to 85°C operating temperature range. Specifications over
Note 6:
In a synchronized application, the internal slope compensation is the –40°C to 85°C operating temperature range are assured by design, increased by 25%. Synchronizing to a significantly higher ratio will reduce characterization and correlation with statistical process controls. The the effective amount of slope compensation, which could result in sub- LTC3783I is guaranteed to meet performance specifications over the full harmonic oscillation for duty cycles greater than 50% –40°C to 125°C operating temperature range.
Note 7
: Rise and fall times are measured at 10% and 90% levels.
Note 3:
TJ is calculated from the ambient temperature TA and power dissipation PD according to the following formula: TJ = TA + (PD • 43°C/W) for the DFN TJ = TA + (PD • 38°C/W) for the TSSOP 3783fb 4 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Block Diagram Operation Package Description Related Parts
