Datasheet LT3825 (Analog Devices) - 9
DescriptionIsolated No-Opto Synchronous Flyback Controller with Wide Input Supply Range
Pages / Page32 / 9 — FLYBACK FEEDBACK AMPLIFIER. TIMING DIAGRAM
File Format / SizePDF / 390 Kb
FLYBACK FEEDBACK AMPLIFIER TIMING DIAGRAM
LT3825
V T1 FLBK FLYBACK R1 LT3825 FEEDBACK AMP • FB 8 – V 1V C 9 R2 V V FB + IN C • – 1.237V + VC PRIMARY SECONDARY C ISOLATED OUT OUTPUT • COLLAPSE MP DETECT MS R ENABLE S Q 3825 FFA
TIMING DIAGRAM
VFLBK PRIMARY SIDE V 0.8 • VFLBK MOSFET DRAIN IN VOLTAGE PG VOLTAGE SG VOLTAGE 3825 TD tON(MIN) MIN ENABLE PG DELAY ENABLE DELAY FEEDBACK AMPLIFIER ENABLED 3825fe 9 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Related Parts
