Datasheet LTC3723 (Analog Devices) - 4
DescriptionSynchronous Push-Pull PWM Controllers
Pages / Page20 / 4 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 347 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
LTC3723-1/LTC3723-2
C. VCC = 9.5V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SSI Soft-Start Current SS = 2.5V 10 13 16 µA SSR Soft-Start Reset Threshold Measured on SS 0.7 0.4 0.1 V FLT Fault Reset Threshold Measured on SS 4.5 4.2 3.5 V
Note 1:
Absolute Maximum Ratings are those values beyond which the life performance specifications from 0°C to 70°C. Specifications over the of a device may be impaired. –40°C to 85°C operating temperature range are assured by design,
Note 2:
Includes leading edge blanking delay, R characterization and correlation with statistical process controls. LEB = 20k, not tested in production.
Note 6:
This IC includes overtemperature protection that is intended to
Note 3:
FB is driven by a servo loop amplifier to control V protect the device during momentary overload conditions. Junction COMP for these tests. temperature will exceed 125°C when overtemperature protection is active.
Note 4:
Set FB to –0.3V, 2.5V and insure that COMP does not phase invert. Continuous operation above the specified maximum operating junction temperature may impair device reliability.
Note 5:
The LTC3723E–1/LTC3723E-2 are guaranteed to meet
W U TYPICAL PERFOR A CE CHARACTERISTICS (TA = 25
C unless otherwise noted) Oscillator Frequency vs Start-Up ICC vs VCC VCC vs ISHUNT Temperature
200 10.50 260 CT = 270pF 150 10.25 250 µA) (V) ( 100 10.00 240 CC I CC V FREQUENCY (kHz) 50 9.75 230 0 9.50 220 0 2 4 6 8 10 0 10 20 30 40 50 – 60 – 40 – 20 0 20 40 60 80 100 VCC (V) ISHUNT (mA) TEMPERATURE (°C) 372312 G01 372312 G02 372312 G03
Leading Edge Blanking Time vs RLEB VREF vs IREF VREF vs Temperature
350 5.05 5.01 300 TJ = 25°C 5.00 5.00 250 TJ = 85°C 4.95 200 (V) (V) 4.99 REF REF 150 V V 4.90 BLANK TIME (ns) T 100 J = –40°C 4.98 4.85 50 0 4.80 4.97 0 10 20 30 40 50 60 70 80 90 100 0 5 10 15 20 25 30 35 40 – 60 – 40 – 20 0 20 40 60 80 100 RLEB (kΩ) IREF (mA) TEMPERATURE (°C) 372312 G04 372312 G05 372312 G06 372312f 4
