link to page 33 ATtiny2313A/4313 the CLKPCE bit within this time-out period does neither extend the time-out period, nor clear the CLKPCE bit. • Bits 6:4 – Res: Reserved Bits These bits are reserved bits in the ATtiny2313A/4313 and will always read as zero. • Bits 3:0 – CLKPS3:0: Clock Prescaler Select Bits 3 - 0 These bits define the division factor between the selected clock source and the internal system clock. These bits can be written run-time to vary the clock frequency to suit the application requirements. As the divider divides the master clock input to the MCU, the speed of all synchro- nous peripherals is reduced when a division factor is used. The division factors are given in Table 6-8 on page 33. To avoid unintentional changes of clock frequency, a special write procedure must be followed to change the CLKPS bits: 1. Write the Clock Prescaler Change Enable (CLKPCE) bit to one and all other bits in CLKPR to zero. 2. Within four cycles, write the desired value to CLKPS while writing a zero to CLKPCE. Interrupts must be disabled when changing prescaler setting to make sure the write procedure is not interrupted. The Application software must ensure that a sufficient division factor is chosen if the selected clock source has a higher frequency than the maximum frequency of the device at the present operating conditions. The device is shipped with the CKDIV8 fuse programmed. Table 6-8. Clock Prescaler Select CLKPS3CLKPS2CLKPS1CLKPS0Clock Division Factor 0 0 0 0 1 0 0 0 1 2 0 0 1 0 4 0 0 1 1 8 0 1 0 0 16 0 1 0 1 32 0 1 1 0 64 0 1 1 1 128 1 0 0 0 256 1 0 0 1 Reserved 1 0 1 0 Reserved 1 0 1 1 Reserved 1 1 0 0 Reserved 1 1 0 1 Reserved 1 1 1 0 Reserved 1 1 1 1 Reserved 33 8246B–AVR–09/11 Document Outline Features 1. Pin Configurations 1.1 Pin Descriptions 1.1.1 VCC 1.1.2 GND 1.1.3 Port A (PA2..PA0) 1.1.4 Port B (PB7..PB0) 1.1.5 Port D (PD6..PD0) 1.1.6 RESET 1.1.7 XTAL1 1.1.8 XTAL2 2. Overview 2.1 Block Diagram 2.2 Comparison Between ATtiny2313A and ATtiny4313 3. About 3.1 Resources 3.2 Code Examples 3.3 Data Retention 4. CPU Core 4.1 Architectural Overview 4.2 ALU – Arithmetic Logic Unit 4.3 Status Register 4.4 General Purpose Register File 4.4.1 The X-register, Y-register, and Z-register 4.5 Stack Pointer 4.6 Instruction Execution Timing 4.7 Reset and Interrupt Handling 4.7.1 Interrupt Response Time 5. Memories 5.1 Program Memory (Flash) 5.2 Data Memory (SRAM) and Register Files 5.2.1 General Purpose Register File 5.2.2 I/O Register File 5.2.3 Data Memory (SRAM) 5.3 Data Memory (EEPROM) 5.3.1 Programming Methods 5.3.2 Read 5.3.3 Erase 5.3.4 Write 5.3.5 Preventing EEPROM Corruption 5.3.6 Program Examples 5.4 Register Description 5.4.1 EEAR – EEPROM Address Register 5.4.2 EEDR – EEPROM Data Register 5.4.3 EECR – EEPROM Control Register 5.4.4 GPIOR2 – General Purpose I/O Register 2 5.4.5 GPIOR1 – General Purpose I/O Register 1 5.4.6 GPIOR0 – General Purpose I/O Register 0 6. Clock System 6.1 Clock Subsystems 6.1.1 CPU Clock – clkCPU 6.1.2 I/O Clock – clkI/O 6.1.3 Flash Clock – clkFLASH 6.2 Clock Sources 6.2.1 Default Clock Source 6.2.2 External Clock 6.2.3 Calibrated Internal RC Oscillator 6.2.4 128 kHz Internal Oscillator 6.2.5 Crystal Oscillator 6.3 System Clock Prescaler 6.3.1 Switching Time 6.4 Clock Output Buffer 6.5 Register Description 6.5.1 OSCCAL – Oscillator Calibration Register 6.5.2 CLKPR – Clock Prescale Register 7. Power Management and Sleep Modes 7.1 Sleep Modes 7.1.1 Idle Mode 7.1.2 Power-Down Mode 7.1.3 Standby Mode 7.2 Software BOD Disable 7.3 Power Reduction Register 7.4 Minimizing Power Consumption 7.4.1 Analog Comparator 7.4.2 Internal Voltage Reference 7.4.3 Brown-out Detector 7.4.4 Watchdog Timer 7.4.5 Port Pins 7.5 Register Description 7.5.1 MCUCR – MCU Control Register 7.5.2 PRR – Power Reduction Register 7.5.3 BODCR – Brown-Out Detector Control Register 8. System Control and Reset 8.1 Resetting the AVR 8.2 Reset Sources 8.2.1 Power-on Reset 8.2.2 External Reset 8.2.3 Brown-out Detection 8.2.4 Watchdog Reset 8.3 Internal Voltage Reference 8.3.1 Voltage Reference Enable Signals and Start-up Time 8.4 Watchdog Timer 8.4.1 Timed Sequences for Changing the Configuration of the Watchdog Timer 8.4.2 Code Example 8.5 Register Description 8.5.1 MCUSR – MCU Status Register 8.5.2 WDTCSR – Watchdog Timer Control and Status Register 9. Interrupts 9.1 Interrupt Vectors 9.2 External Interrupts 9.2.1 Low Level Interrupt 9.2.2 Pin Change Interrupt Timing 9.3 Register Description 9.3.1 MCUCR – MCU Control Register 9.3.2 GIMSK – General Interrupt Mask Register 9.3.3 GIFR – General Interrupt Flag Register 9.3.4 PCMSK2 – Pin Change Mask Register 2 9.3.5 PCMSK1 – Pin Change Mask Register 1 9.3.6 PCMSK0 – Pin Change Mask Register 0 10. I/O-Ports 10.1 Ports as General Digital I/O 10.1.1 Configuring the Pin 10.1.2 Toggling the Pin 10.1.3 Switching Between Input and Output 10.1.4 Reading the Pin Value 10.1.5 Digital Input Enable and Sleep Modes 10.1.6 Unconnected Pins 10.1.7 Program Examples 10.2 Alternate Port Functions 10.2.1 Alternate Functions of Port A 10.2.2 Alternate Functions of Port B 10.2.3 Alternate Functions of Port D 10.3 Register Description 10.3.1 MCUCR – MCU Control Register 10.3.2 PORTA – Port A Data Register 10.3.3 DDRA – Port A Data Direction Register 10.3.4 PINA – Port A Input Pins Address 10.3.5 PORTB – Port B Data Register 10.3.6 DDRB – Port B Data Direction Register 10.3.7 PINB – Port B Input Pins Address 10.3.8 PORTD – Port D Data Register 10.3.9 DDRD – Port D Data Direction Register 10.3.10 PIND – Port D Input Pins Address 11. 8-bit Timer/Counter0 with PWM 11.1 Features 11.2 Overview 11.2.1 Registers 11.2.2 Definitions 11.3 Clock Sources 11.4 Counter Unit 11.5 Output Compare Unit 11.5.1 Force Output Compare 11.5.2 Compare Match Blocking by TCNT0 Write 11.5.3 Using the Output Compare Unit 11.6 Compare Match Output Unit 11.6.1 Compare Output Mode and Waveform Generation 11.7 Modes of Operation 11.7.1 Normal Mode 11.7.2 Clear Timer on Compare Match (CTC) Mode 11.7.3 Fast PWM Mode 11.7.4 Phase Correct PWM Mode 11.8 Timer/Counter Timing Diagrams 11.9 Register Description 11.9.1 TCCR0A – Timer/Counter Control Register A 11.9.2 TCCR0B – Timer/Counter Control Register B 11.9.3 TCNT0 – Timer/Counter Register 11.9.4 OCR0A – Output Compare Register A 11.9.5 OCR0B – Output Compare Register B 11.9.6 TIMSK – Timer/Counter Interrupt Mask Register 11.9.7 TIFR – Timer/Counter Interrupt Flag Register 12. 16-bit Timer/Counter1 12.1 Features 12.2 Overview 12.2.1 Registers 12.2.2 Definitions 12.2.3 Compatibility 12.3 Timer/Counter Clock Sources 12.4 Counter Unit 12.5 Input Capture Unit 12.5.1 Input Capture Trigger Source 12.5.2 Noise Canceler 12.5.3 Using the Input Capture Unit 12.6 Output Compare Units 12.6.1 Force Output Compare 12.6.2 Compare Match Blocking by TCNT1 Write 12.6.3 Using the Output Compare Unit 12.7 Compare Match Output Unit 12.7.1 Compare Output Mode and Waveform Generation 12.8 Modes of Operation 12.8.1 Normal Mode 12.8.2 Clear Timer on Compare Match (CTC) Mode 12.8.3 Fast PWM Mode 12.8.4 Phase Correct PWM Mode 12.8.5 Phase and Frequency Correct PWM Mode 12.9 Timer/Counter Timing Diagrams 12.10 Accessing 16-bit Registers 12.10.1 Reusing the Temporary High Byte Register 12.11 Register Description 12.11.1 TCCR1A – Timer/Counter1 Control Register A 12.11.2 TCCR1B – Timer/Counter1 Control Register B 12.11.3 TCCR1C – Timer/Counter1 Control Register C 12.11.4 TCNT1H and TCNT1L – Timer/Counter1 12.11.5 OCR1AH and OCR1AL – Output Compare Register 1 A 12.11.6 OCR1BH and OCR1BL – Output Compare Register 1 B 12.11.7 ICR1H and ICR1L – Input Capture Register 1 12.11.8 TIMSK – Timer/Counter Interrupt Mask Register 12.11.9 TIFR – Timer/Counter Interrupt Flag Register 13. Timer/Counter0 and Timer/Counter1 Prescalers 13.1 Internal Clock Source 13.2 Prescaler Reset 13.3 External Clock Source 13.4 Register Description 13.4.1 GTCCR – General Timer/Counter Control Register 14. USART 14.1 Features 14.2 Overview 14.2.1 AVR USART vs. AVR UART – Compatibility 14.3 Clock Generation 14.3.1 Internal Clock Generation – The Baud Rate Generator 14.3.2 Double Speed Operation (U2X) 14.3.3 External Clock 14.3.4 Synchronous Clock Operation 14.4 Frame Formats 14.4.1 Parity Bit Calculation 14.5 USART Initialization 14.6 Data Transmission – The USART Transmitter 14.6.1 Sending Frames with 5 to 8 Data Bit 14.6.2 Sending Frames with 9 Data Bit 14.6.3 Transmitter Flags and Interrupts 14.6.4 Parity Generator 14.6.5 Disabling the Transmitter 14.7 Data Reception – The USART Receiver 14.7.1 Receiving Frames with 5 to 8 Data Bits 14.7.2 Receiving Frames with 9 Data Bits 14.7.3 Receive Compete Flag and Interrupt 14.7.4 Receiver Error Flags 14.7.5 Parity Checker 14.7.6 Disabling the Receiver 14.7.7 Flushing the Receive Buffer 14.8 Asynchronous Data Reception 14.8.1 Asynchronous Clock Recovery 14.8.2 Asynchronous Data Recovery 14.8.3 Asynchronous Operational Range 14.9 Multi-processor Communication Mode 14.9.1 Using MPCM 14.10 Register Description 14.10.1 UDR – USART I/O Data Register 14.10.2 UCSRA – USART Control and Status Register A 14.10.3 UCSRB – USART Control and Status Register B 14.10.4 UCSRC – USART Control and Status Register C 14.10.5 UBRRL and UBRRH – USART Baud Rate Registers 14.11 Examples of Baud Rate Setting 15. USART in SPI Mode 15.1 Features 15.2 Overview 15.3 Clock Generation 15.4 SPI Data Modes and Timing 15.5 Frame Formats 15.5.1 USART MSPIM Initialization 15.6 Data Transfer 15.6.1 Transmitter and Receiver Flags and Interrupts 15.6.2 Disabling the Transmitter or Receiver 15.7 AVR USART MSPIM vs. AVR SPI 15.8 Register Description 15.8.1 UDR – USART MSPIM I/O Data Register 15.8.2 UCSRA – USART MSPIM Control and Status Register A 15.8.3 UCSRB – USART MSPIM Control and Status Register B 15.8.4 UCSRC – USART MSPIM Control and Status Register C 15.8.5 UBRRL and UBRRH – USART MSPIM Baud Rate Registers 16. USI – Universal Serial Interface 16.1 Features 16.2 Overview 16.3 Functional Descriptions 16.3.1 Three-wire Mode 16.3.2 SPI Master Operation Example 16.3.3 SPI Slave Operation Example 16.3.4 Two-wire Mode 16.3.5 Start Condition Detector 16.3.6 Clock speed considerations 16.4 Alternative USI Usage 16.4.1 Half-Duplex Asynchronous Data Transfer 16.4.2 4-Bit Counter 16.4.3 12-Bit Timer/Counter 16.4.4 Edge Triggered External Interrupt 16.4.5 Software Interrupt 16.5 Register Description 16.5.1 USICR – USI Control Register 16.5.2 USISR – USI Status Register 16.5.3 USIDR – USI Data Register 16.5.4 USIBR – USI Buffer Register 17. Analog Comparator 17.1 Register Description 17.1.1 ACSR – Analog Comparator Control and Status Register 17.1.2 DIDR – Digital Input Disable Register 18. debugWIRE On-chip Debug System 18.1 Features 18.2 Overview 18.3 Physical Interface 18.4 Software Break Points 18.5 Limitations of debugWIRE 18.6 Register Description 18.6.1 DWDR – debugWire Data Register 19. Self-Programming 19.1 Features 19.2 Overview 19.3 Lock Bits 19.4 Self-Programming the Flash 19.4.1 Addressing the Flash During Self-Programming 19.4.2 Page Erase 19.4.3 Page Load 19.4.4 Page Write 19.4.5 SPMCSR Can Not Be Written When EEPROM is Programmed 19.5 Preventing Flash Corruption 19.6 Programming Time for Flash when Using SPM 19.7 Register Description 19.7.1 SPMCSR – Store Program Memory Control and Status Register 20. Lock Bits, Fuse Bits and Device Signature 20.1 Lock Bits 20.2 Fuse Bits 20.2.1 Latching of Fuses 20.3 Device Signature Imprint Table 20.3.1 Calibration Byte 20.3.2 Signature Bytes 20.4 Reading Lock Bits, Fuse Bits and Signature Data from Software 20.4.1 Lock Bit Read 20.4.2 Fuse Bit Read 20.4.3 Device Signature Imprint Table Read 21. External Programming 21.1 Memory Parametrics 21.2 Parallel Programming 21.2.1 Enter Programming Mode 21.2.2 Considerations for Efficient Programming 21.2.3 Chip Erase 21.2.4 Programming the Flash 21.2.5 Programming the EEPROM 21.2.6 Reading the Flash 21.2.7 Reading the EEPROM 21.2.8 Programming Low Fuse Bits 21.2.9 Programming High Fuse Bits 21.2.10 Programming Extended Fuse Bits 21.2.11 Programming the Lock Bits 21.2.12 Reading Fuse and Lock Bits 21.2.13 Reading Signature Bytes 21.2.14 Reading the Calibration Byte 21.3 Serial Programming 21.3.1 Pin Mapping 21.3.2 Programming Algorithm 21.3.3 Programming Instruction Set 21.4 Programming Time for Flash and EEPROM 22. Electrical Characteristics 22.1 Absolute Maximum Ratings* 22.2 DC Characteristics 22.3 Speed 22.4 Clock Characteristics 22.4.1 Calibrated Internal RC Oscillator Accuracy 22.4.2 External Clock Drive 22.5 System and Reset Characteristics 22.5.1 Enhanced Power-On Reset 22.5.2 Brown-Out Detection 22.6 Analog Comparator Characteristics 22.7 Parallel Programming Characteristics 22.8 Serial Programming Characteristics 23. Typical Characteristics 23.1 Effect of Power Reduction 23.2 ATtiny2313A 23.2.1 Current Consumption in Active Mode 23.2.2 Current Consumption in Idle Mode 23.2.3 Current Consumption in Power-down Mode 23.2.4 Current Consumption in Reset 23.2.5 Current Consumption of Peripheral Units 23.2.6 Pull-up Resistors 23.2.7 Output Driver Strength 23.2.8 Input Thresholds and Hysteresis (for I/O Ports) 23.2.9 BOD, Bandgap and Reset 23.2.10 Internal Oscillator Speed 23.3 ATtiny4313 23.3.1 Current Consumption in Active Mode 23.3.2 Current Consumption in Idle Mode 23.3.3 Current Consumption in Power-down Mode 23.3.4 Current Consumption in Reset 23.3.5 Current Consumption of Peripheral Units 23.3.6 Pull-up Resistors 23.3.7 Output Driver Strength 23.3.8 Input Thresholds and Hysteresis (for I/O Ports) 23.3.9 BOD, Bandgap and Reset 23.3.10 Internal Oscillator Speed 24. Register Summary 25. Instruction Set Summary 26. Ordering Information 26.1 ATtiny2313A 26.2 ATtiny4313 27. Packaging Information 27.1 20P3 27.2 20S 27.3 20M1 27.4 20M2 28. Errata 28.1 ATtiny2313A 28.1.1 Rev. D 28.1.2 Rev. A – C 28.2 ATtiny4313 28.2.1 Rev. A 29. Datasheet Revision History 29.1 Rev. 8246B – 10/11 29.2 Rev. 8246A – 11/09 Table of Contents
