Datasheet ATmega16M1, ATmega32M1, ATmega64M1 - Summary (Atmel) - 9
Manufacturer | Atmel |
Description | 8-bit AVR Microcontroller |
Pages / Page | 18 / 9 — Ordering Information. 2.1. ATmega16M1. Speed [MHz]. Power Supply [V]. … |
File Format / Size | PDF / 313 Kb |
Ordering Information. 2.1. ATmega16M1. Speed [MHz]. Power Supply [V]. Ordering Code. Package. Operational Range. Note: . Package Type. 2.2
![Ordering Information 2.1 ATmega16M1 Speed [MHz] Power Supply [V] Ordering Code Package Operational Range Note: Package Type 2.2](https://www.rlocman.ru/datasheet/img.php?di=149315&p=8)
2. Ordering Information 2.1. ATmega16M1 Speed [MHz] Power Supply [V] Ordering Code Package Operational Range
16 2.7 - 5.5 ATmega16M1-AU 32A Industrial ATmega16M1-MU PV (-40°C to 85°C)
Note:
All packages are Pb free, fully LHF.
Package Type
32A 32-lead, Thin (1.0mm) Plastic Quad Flat Package (TQFP) PV PV, 32-lead, 7.0mm × 7.0mm body, 0.65mm pitch quad flat no lead package (QFN)
2.2. ATmega32M1 Speed [MHz] Power Supply [V] Ordering Code Package Operational Range
16 2.7 - 5.5 ATmega32M1-AU 32A Industrial ATmega32M1-MU PV (-40°C to 85°C)
Note:
Package Type
2.3. ATmega64M1 Speed [MHz] Power Supply [V] Ordering Code Package Operational Range
16 2.7 - 5.5 ATmega64M1-AU 32A Industrial ATmega64M1-MU PV (-40°C to 85°C)
Note:
Package Type
32A 32-lead, Thin (1.0mm) Plastic Quad Flat Package (TQFP) PV PV, 32-lead, 7.0mm × 7.0mm body, 0.65mm pitch quad flat no lead package (QFN) Atmel ATmega16M1/32M1/64M1 [DATASHEET] 9 Atmel-8209F-ATmega16M1/32M1/64M1_Datasheet_Summary-10/2016 Document Outline Introduction Features Table of Contents 1. Pin configurations 1.1. Pin descriptions 2. Ordering Information 2.1. ATmega16M1 2.2. ATmega32M1 2.3. ATmega64M1 3. Overview 3.1. Block diagram 3.2. Pin descriptions 3.2.1. VCC 3.2.2. GND 3.2.3. Port B (PB7..PB0) 3.2.4. Port C (PC7..PC0) 3.2.5. Port D (PD7..PD0) 3.2.6. Port E (PE2..0) RESET/ XTAL1/XTAL2 3.2.7. AVCC 3.2.8. AREF 4. Resources 5. About code examples 6. Data retention 7. Packaging Information 7.1. 32-pin 32A 7.2. PV 32 QFN
