Datasheet ATmega163, ATmega163L - Summary (Atmel) - 4
ManufacturerAtmel
Description8-bit AVR Microcontroller with 16K Bytes In-System Programmable Flash. Not Recommend for New Designs. Use ATmega16
Pages / Page18 / 4 — Pin Descriptions. VCC. GND. Port A (PA7..PA0). Port B (PB7..PB0). Port C …
File Format / SizePDF / 324 Kb
Pin Descriptions. VCC. GND. Port A (PA7..PA0). Port B (PB7..PB0). Port C (PC7..PC0). ATmega163(L)
Pin Descriptions VCC GND Port A (PA7..PA0) Port B (PB7..PB0) Port C (PC7..PC0) ATmega163(L)
cycle. The resulting architecture is more code efficient while achieving throughputs up to ten times faster than conventional CISC microcontrollers. The ATmega163 provides the following features: 16K bytes of In-System Self-Program- mable Flash, 512 bytes EEPROM, 1024 bytes SRAM, 32 general purpose I/O lines, 32 general purpose working registers, three flexible Timer/Counters with compare modes, internal and external interrupts, a byte oriented Two-wire Serial Interface, an 8-channel, 10-bit ADC, a programmable Watchdog Timer with internal Oscillator, a programmable serial UART, an SPI serial port, and four software selectable power saving modes. The Idle mode stops the CPU while allowing the SRAM, Timer/Counters, SPI port, and inter- rupt system to continue functioning. The Power-down mode saves the register contents but freezes the Oscillator, disabling all other chip functions until the next interrupt or Hardware Reset. In Power-save mode, the asynchronous Timer Oscillator continues to run, allowing the user to maintain a timer base while the rest of the device is sleeping. The ADC Noise Reduction mode stops the CPU and all I/O modules except asynchro- nous timer and ADC, to minimize switching noise during ADC conversions. The On-chip ISP Flash can be programmed through an SPI serial interface or a conven- tional programmer. By installing a Self-Programming Boot Loader, the microcontroller can be updated within the application without any external components. The Boot Pro- gram can use any interface to download the application program in the Application Flash memory. By combining an 8-bit CPU with In-System Self-Programmable Flash on a monolithic chip, the Atmel ATmega163 is a powerful microcontroller that provides a highly flexible and cost effective solution to many embedded control applications. The ATmega163 AVR is supported with a full suite of program and system development tools including: C compilers, macro assemblers, program debugger/simulators, In-Cir- cuit Emulators, and evaluation kits.
Digital supply voltage.
GND
Digital ground.
Port A (PA7..PA0)
Port A serves as the analog inputs to the A/D Converter. Port A also serves as an 8-bit bi-directional I/O port, if the A/D Converter is not used. Port pins can provide internal pull-up resistors (selected for each bit). The Port A output buffers can sink 20mA and can drive LED displays directly. When pins PA0 to PA7 are used as inputs and are externally pulled low, they will source current if the internal pull- up resistors are activated. The Port A pins are tristated when a reset condition becomes active, even if the clock is not running.
Port B (PB7..PB0)
Port B is an 8-bit bi-directional I/O port with internal pull-up resistors (selected for each bit). The Port B output buffers can sink 20 mA. As inputs, Port B pins that are externally pulled low will source current if the pull-up resistors are activated. Port B also serves the functions of various special features of the ATmega83/163 as listed on page 117. The Port B pins are tristated when a reset condition becomes active, even if the clock is not running.
Port C (PC7..PC0)
Port C is an 8-bit bi-directional I/O port with internal pull-up resistors (selected for each bit). The Port C output buffers can sink 20 mA. As inputs, Port C pins that are externally pulled low will source current if the pull-up resistors are activated. The Port C pins are tristated when a reset condition becomes active, even if the clock is not running.
4 ATmega163(L)
1142ES–AVR–02/03 Document Outline Features Pin Configurations Description Block Diagram Pin Descriptions VCC GND Port A (PA7..PA0) Port B (PB7..PB0) Port C (PC7..PC0) Port D (PD7..PD0) RESET XTAL1 XTAL2 AVCC AREF AGND Register Summary Instruction Set Summary Ordering Information Packaging Information 44A 40P6 Erratas ATmega163(L) Errata Rev. F ChangeLog Changes from Rev. 1142C-09/01 to Rev. 1142D-09/02 Changes from Rev. 1142D-09/09 to Rev. 1142E-02/03
