Datasheet AT90S1200 (Atmel) - 3
ManufacturerAtmel
Description8-bit AVR Microcontroller with 1K Byte of In-System Programmable Flash
Pages / Page71 / 3 — AT90S1200. Pin Descriptions. VCC. GND. Port B (PB7..PB0). Port D …
AT90S1200. Pin Descriptions. VCC. GND. Port B (PB7..PB0). Port D (PD6..PD0). RESET. XTAL1. XTAL2. Crystal Oscillator
AT90S1200 Pin Descriptions VCC GND Port B (PB7..PB0) Port D (PD6..PD0) RESET XTAL1 XTAL2 Crystal Oscillator
link to page 30 link to page 34 link to page 4 link to page 4
AT90S1200
ing the Registers, Timer/Counter, Watchdog and Interrupt system to continue functioning. The Power-down mode saves the register contents but freezes the Oscilla- tor, disabling all other chip functions until the next External Interrupt or hardware Reset. The device is manufactured using Atmel’s high-density nonvolatile memory technology. The On-chip In-System Programmable Flash allows the program memory to be repro- grammed in-system through an SPI serial interface or by a conventional nonvolatile memory programmer. By combining an enhanced RISC 8-bit CPU with In-System Pro- grammable Flash on a monolithic chip, the Atmel AT90S1200 is a powerful microcontroller that provides a highly flexible and cost-effective solution to many embed- ded control applications. The AT90S1200 AVR is supported with a full suite of program and system development tools including: macro assemblers, program debugger/simulators, in-circuit emulators, and evaluation kits.
Supply voltage pin.
GND
Ground pin.
Port B (PB7..PB0)
Port B is an 8-bit bi-directional I/O port. Port pins can provide internal pull-up resistors (selected for each bit). PB0 and PB1 also serve as the positive input (AIN0) and the negative input (AIN1), respectively, of the On-chip Analog Comparator. The Port B out- put buffers can sink 20 mA and thus drive LED displays directly. When pins PB0 to PB7 are used as inputs and are externally pulled low, they will source current if the internal pull-up resistors are activated. The Port B pins are tri-stated when a reset condition becomes active, even if the clock is not active. Port B also serves the functions of various special features of the AT90S1200 as listed on page 30.
Port D (PD6..PD0)
Port D has seven bi-directional I/O pins with internal pull-up resistors, PD6..PD0. The Port D output buffers can sink 20 mA. As inputs, Port D pins that are externally pulled low will source current if the pull-up resistors are activated. The Port D pins are tri-stated when a reset condition becomes active, even if the clock is not active. Port D also serves the functions of various special features of the AT90S1200 as listed on page 34.
RESET
Reset input. A low level on this pin for more than 50 ns will generate a reset, even if the clock is not running. Shorter pulses are not guaranteed to generate a reset.
XTAL1
Input to the inverting oscillator amplifier and input to the internal clock operating circuit.
XTAL2
Output from the inverting oscillator amplifier.
Crystal Oscillator
XTAL1 and XTAL2 are input and output, respectively, of an inverting amplifier which can be configured for use as an On-chip Oscillator, as shown in Figure 2. Either a quartz crystal or a ceramic resonator may be used. To drive the device from an external clock source, XTAL2 should be left unconnected while XTAL1 is driven as shown in Figure 3.
3
0838H–AVR–03/02 Document Outline Features Pin Configuration Description Block Diagram Pin Descriptions VCC GND Port B (PB7..PB0) Port D (PD6..PD0) RESET XTAL1 XTAL2 Crystal Oscillator On-chip RC Oscillator Architectural Overview General Purpose Register File ALU – Arithmetic Logic Unit In-System Programmable Flash Program Memory Program and Data Addressing Modes Register Direct, Single Register Rd Register Indirect Register Direct, Two Registers Rd and Rr I/O Direct Relative Program Addressing, RJMP and RCALL Subroutine and Interrupt Hardware Stack EEPROM Data Memory Instruction Execution Timing I/O Memory Status Register – SREG Reset and Interrupt Handling Reset Sources Power-on Reset External Reset Watchdog Reset Interrupt Handling General Interrupt Mask Register – GIMSK Timer/Counter Interrupt Mask Register – TIMSK Timer/Counter Interrupt FLAG Register – TIFR External Interrupts Interrupt Response Time MCU Control Register – MCUCR Sleep Modes Idle Mode Power-down Mode Timer/Counter0 Timer/Counter0 Prescaler Timer/Counter0 Control Register – TCCR0 Timer/Counter0 – TCNT0 Watchdog Timer Watchdog Timer Control Register – WDTCR EEPROM Read/Write Access EEPROM Address Register – EEAR EEPROM Data Register – EEDR EEPROM Control Register – EECR Prevent EEPROM Corruption Analog Comparator Analog Comparator Control and Status Register – ACSR I/O Ports Port B Port B Data Register – PORTB Port B Data Direction Register – DDRB Port B Input Pin Address – PINB Port B as General Digital I/O Alternate Functions of Port B Port B Schematics Port D Port D Data Register – PORTD Port D Data Direction Register – DDRD Port D Input Pins Address – PIND Port D as General Digital I/O Alternate Functions for Port D Port D Schematics Memory Programming Program and Data Memory Lock Bits Fuse Bits Signature Bytes Programming the Flash and EEPROM Parallel Programming Signal Names Enter Programming Mode Chip Erase Programming the Flash Reading the Flash Programming the EEPROM Reading the EEPROM Programming the Fuse Bits Programming the Lock Bits Reading the Fuse and Lock Bits Reading the Signature Bytes Parallel Programming Characteristics Serial Downloading Serial Programming Algorithm Data Polling EEPROM Data Polling Flash Serial Programming Characteristics Electrical Characteristics Absolute Maximum Ratings* DC Characteristics External Clock Drive Waveforms External Clock Drive Typical Characteristics AT90S1200 Register Summary Instruction Set Summary Ordering Information(1) Packaging Information 20P3 20S 20Y Table of Contents
