Datasheet ATtiny22, ATtiny22L - Preliminary (Atmel) - 5
ManufacturerAtmel
Description8-bit AVR Microcontroller with 2K Bytes of In-System Programmable Flash
Pages / Page59 / 5 — ATtiny22/22L. Figure 4. EEPROM Data Memory
ATtiny22/22L Figure 4 EEPROM Data Memory
link to page 4
ATtiny22/22L
The ALU supports arithmetic and logic functions between registers or between a constant and a register. Single register operations are also executed in the ALU. Figure 3 shows the ATtiny22/L AVR RISC microcontroller architecture. In addition to the register operation, the conventional memory addressing modes can be used on the register file as well. This is enabled by the fact that the register file is assigned the 32 lowermost Data Space addresses ($00 - $1F), allowing them to be accessed as though they were ordinary memory locations. The I/O memory space contains 64 addresses for CPU peripheral functions as Control Registers, Timer/Counters, A/D-converters, and other I/O functions. The I/O memory can be accessed directly, or as the Data Space locations follow- ing those of the register file, $20 - $5F. The AVR has Harvard architecture - with separate memories and buses for program and data. The program memory is accessed with a two stage pipeline. While one instruction is being executed, the next instruction is pre-fetched from the program memory. This concept enables instructions to be executed in every clock cycle. The program memory is in-system downloadable Flash memory. With the relative jump and call instructions, the whole 1K address space is directly accessed. Most AVR instructions have a single 16-bit word format. Every program memory address contains a 16- or 32-bit instruction. During interrupts and subroutine calls, the return address program counter (PC) is stored on the stack. The stack is effectively allocated in the general data SRAM, and consequently the stack size is only limited by the total SRAM size and the usage of the SRAM. All user programs must initialize the SP in the reset routine (before subroutines or interrupts are executed). The 8-bit stack pointer SP is read/write accessible in the I/O space. The 128 bytes data SRAM + register file and I/O registers can be easily accessed through the five different addressing modes supported in the AVR architecture. The memory spaces in the AVR architecture are all linear and regular memory maps.
Figure 4.
Memory Maps
EEPROM Data Memory
$000 EEPROM (128 x 8) $07F
5
Document Outline Features Description Block Diagram Pin Descriptions ATtiny22/L VCC GND Port B (PB4..PB0) RESET CLOCK Clock Options External Clock Architectural Overview General Purpose Register File X-Register, Y-Register, and Z-Register ALU - Arithmetic Logic Unit In-System Programmable Flash Program Memory EEPROM Data Memory SRAM Data Memory Program and Data Addressing Modes Register Direct, Single Register Rd Register Direct, Two Registers Rd and Rr I/O Direct Data Direct Data Indirect with Displacement Data Indirect Data Indirect With Pre-Decrement Data Indirect With Post-Increment Constant Addressing Using the LPM Instruction Indirect Program Addressing, IJMP and ICALL Relative Program Addressing, RJMP and RCALL Memory Access and Instruction Execution Timing I/O Memory Status Register - SREG Stack Pointer - SPL Reset and Interrupt Handling Reset Sources Power-On Reset External Reset Watchdog Reset MCU Status Register - MCUSR Interrupt Handling General Interrupt Mask Register - GIMSK General Interrupt Flag Register - GIFR Timer/Counter Interrupt Mask Register - TIMSK Timer/Counter Interrupt FLAG Register - TIFR External Interrupt Interrupt Response Time MCU Control Register - MCUCR Sleep Modes Idle Mode Power Down Mode Timer/Counter Timer/Counter Prescaler 8-Bit Timer/Counter0 Timer/Counter0 Control Register - TCCR0 Timer Counter 0 - TCNT0 Watchdog Timer Watchdog Timer Control Register - WDTCR EEPROM Read/Write Access EEPROM Address Register - EEAR EEPROM Data Register - EEDR EEPROM Control Register - EECR Prevent EEPROM Corruption I/O Port B Port B Data Register - PORTB Port B Data Direction Register - DDRB Port B Input Pins Address - PINB General Digital I/O Alternate Functions of Port B CLOCK - Port B, Bit 3 SCK/T0 - Port B, Bit 2 MISO - Port B, Bit 1 MOSI - Port B, Bit 0 Memory Programming Program and Data Memory Lock Bits Fuse Bits Signature Bytes Programming the Flash and EEPROM High-Voltage Serial Programming High-Voltage Serial Programming Algorithm High-Voltage Serial Programming Characteristics Low-Voltage Serial Downloading Low-Voltage Serial Programming Algorithm Data Polling EEPROM Data Polling Flash Low-Voltage Serial Programming Characteristics Electrical Characteristics Absolute Maximum Ratings* DC Characteristics External Clock Drive Waveforms External Clock Drive Typical characteristics Register Summary Instruction Set Summary (Continued) Ordering Information
