Datasheet ADM3260 (Analog Devices) - 9
DescriptionHot Swappable, Dual I2C Isolators with Integrated DC-to-DC Converter
Pages / Page19 / 9 — Data Sheet. ADM3260. RECOMMENDED OPERATING CONDITIONS. Table 12. …
RevisionD
File Format / SizePDF / 629 Kb
Data Sheet. ADM3260. RECOMMENDED OPERATING CONDITIONS. Table 12. Parameter. Value
Data Sheet ADM3260 RECOMMENDED OPERATING CONDITIONS Table 12 Parameter Value
link to page 10
Data Sheet ADM3260 RECOMMENDED OPERATING CONDITIONS Table 12. Parameter Value
OPERATING TEMPERATURE1 −40°C to +105°C ISOLATED CONVERTER Supply Voltages2 VIN at VISO Set to Regulate to 3.3 V 3.0 V to 5.5 V VIN at VISO Set to Regulate to 5 V 4.5 V to 5.5 V DIGITAL ISOLATOR Supply Voltages (VDDISO, VDDP)3 3.0 V to 5.5 V Input/Output Signal Voltage (VSDA1, VSCL1, VSDA2, VSCL2) 5.5 V Capacitive Load Side 1 (CL1) 40 pF Side 2 (CL2) 400 pF STATIC OUTPUT LOADING Side 1 (ISDA1, ISCL1) 0.5 mA to 3 mA Side 2 (ISDA2, ISCL2) 0.5 mA to 30 mA 1 Operation at 105°C requires reduction of the maximum load current (see Table 13). 2 Each voltage is relative to its respective ground. 3 All voltages are relative to their respective ground. Rev. D | Page 9 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/5 V SECONDARY ISOLATED SUPPLY ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY ELECTRICAL CHARACTERISTICS—3.3 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY DC-TO-DC CONVERTER CHARACTERISTICS DIGITAL ISOLATOR DC SPECIFICATIONS DIGITAL ISOLATOR AC SPECIFICATIONS PACKAGE CHARACTERISTICS REGULATORY APPROVALS INSULATION AND SAFETY RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION VISO VOLTAGE TRUTH TABLE PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CONDITION APPLICATIONS INFORMATION FUNCTIONAL DESCRIPTION DIGITAL ISOLATOR STARTUP TYPICAL APPLICATION DIAGRAM PCB LAYOUT THERMAL ANALYSIS EMI CONSIDERATIONS INSULATION LIFETIME APPLICATIONS EXAMPLE OUTLINE DIMENSIONS ORDERING GUIDE
