Datasheet ADUM5400 (Analog Devices)
Description | Quad-Channel Isolator with Integrated DC-to-DC Converter |
Pages / Page | 16 / 1 — Quad-Channel Isolator with. Integrated DC-to-DC Converter. Data Sheet. … |
Revision | B |
File Format / Size | PDF / 339 Kb |
Quad-Channel Isolator with. Integrated DC-to-DC Converter. Data Sheet. ADuM5400. FEATURES. GENERAL DESCRIPTION. iso
link to page 16 link to page 1
Quad-Channel Isolator with Integrated DC-to-DC Converter Data Sheet ADuM5400 FEATURES GENERAL DESCRIPTION iso Power integrated, isolated dc-to-dc converter
The ADuM54001 device is a quad-channel digital isolator with
Regulated 5 V output
isoPower®, an integrated, isolated dc-to-dc converter. Based on
500 mW output power
the Analog Devices, Inc., iCoupler® technology, the dc-to-dc
Quad dc-to-25 Mbps (NRZ) signal isolation channels
converter provides up to 500 mW of regulated, isolated power
Schmitt trigger inputs
with 5.0 V input and 5.0 V output voltages. This architecture
16-lead SOIC package with >7.6 mm creepage
eliminates the need for a separate, isolated dc-to-dc converter in
High temperature operation: 105°C maximum
low power, isolated designs. The iCoupler chip scale transformer
High common-mode transient immunity: >25 kV/μs
technology is used to isolate the logic signals and the magnetic
Safety and regulatory approvals
components of the dc-to-dc converter. The result is a small form
UL recognition
factor, total isolation solution.
2500 V rms for 1 minute per UL 1577
The ADuM5400 isolator provides four independent isolation
CSA Component Acceptance Notice #5A
channels in two speed grades (see the Ordering Guide for more
VDE certificate of conformity (pending)
information).
IEC 60747-5-2 (VDE 0884, Part 2) V
isoPower uses high frequency switching elements to transfer
IORM = 560 V peak
power through its transformer. Special care must be taken
during printed circuit board (PCB) layout to meet emissions
RS-232/RS-422/RS-485 transceivers
standards. Refer to the AN-0971 Application Note for details
Industrial field bus isolation
on board layout recommendations.
Power supply start-up bias and gate drives Isolated sensor interfaces Industrial PLCs FUNCTIONAL BLOCK DIAGRAM V 1 OSC RECT REG 16 DD1 VISO GND 2 15 1 GNDISO V 3 14 IA VOA 4-CHANNEL i COUPLER CORE V 4 13 IB VOB ADuM5400 V 5 12 IC VOC V 6 11 ID VOD V 7 10 DDL VISO
01
GND
0
8 9 1 GNDISO
509- 07 Figure 1. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 6,903,578; and 7,075,329.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices fo r its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2008–2012 Analog Devices, Inc. Al l rights reserved.
Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics Package Characteristics Regulatory Information Insulation and Safety Related Specifications IEC 60747-5-2 (VDE 0884, Part 2):2003-01 Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Applications Information PCB Layout EMI Considerations Propagation Delay Parameters DC Correctness and Magnetic Field Immunity Power Consumption Power Considerations Thermal Analysis Insulation Lifetime Outline Dimensions Ordering Guide
