DatasheetsDatasheet ADuM5200W, ADuM5201W, ADuM5202W …
Datasheet ADuM5200W, ADuM5201W, ADuM5202W (Analog Devices)
Description | Dual-Channel, 2.5 kV Isolators with Integrated DC-to-DC Converter |
Pages / Page | 28 / 1 — Dual-Channel, 2.5 kV Isolators with. Integrated DC-to-DC Converter. … |
File Format / Size | PDF / 521 Kb |
Dual-Channel, 2.5 kV Isolators with. Integrated DC-to-DC Converter. Automotive Products. ADuM5200W/. ADuM5201W. /ADuM5202W
link to page 1 link to page 25 link to page 1
Dual-Channel, 2.5 kV Isolators with Integrated DC-to-DC Converter Automotive Products ADuM5200W/ ADuM5201W /ADuM5202W FEATURES FUNCTIONAL BLOCK DIAGRAMS Qualified for automotive applications iso Power integrated, isolated dc-to-dc converter V 1 OSC RECT REG 16 DD1 VISO Regulated 3.3 V or 5 V output GND 2 15 1 GNDISO Up to 400 mW output power V 3 14 IA/VOA VIA/VOA Dual, dc-to-25 Mbps (NRZ) signal isolation channels 2-CHANNEL i COUPLER CORE 16-lead SOIC package with 7.6 mm creepage V 4 13 IB/VOB VIB/VOB High temperature operation: 105°C maximum RC 5 12 IN NC High common-mode transient immunity: >25 kV/µs RC 6 11 SEL VSEL Safety and regulatory approvals ADuM5200W/ V 7 ADuM5201W/ 10 V UL recognition E1/NC E2/NC ADuM5202W
001
2500 V rms for 1 minute per UL 1577 GND 8 9 1 GNDISO
10436-
CSA Component Acceptance Notice #5A)
Figure 1.
VDE certificate of conformity IEC 60747-5-2 (VDE 0884, Part 2):2003-01 V VIA VOA IORM = 560 VPEAK 3 14 APPLICATIONS ADuM5200W VIB VOB
002
4 13 Industrial field bus isolation
10436-
Power supply start-up bias and gate drives
Figure 2. ADuM5200W
Isolated sensor interfaces Automotive systems VIA VOA GENERAL DESCRIPTION 3 14 ADuM5201W
The ADuM5200W/ADuM5201W/ADuM5202W1 are dual-
VOB VIB
003
4 13
channel digital isolators with isoPower®, an integrated, isolated dc- 10436- to-dc converter. Based on the Analog Devices, Inc., iCoupler® Figure 3. ADuM5201W technology, the dc-to-dc converter provides up to 500 mW of regulated, isolated power at either 5.0 V or 3.3 V from a 5.0 V input
VOA VIA
supply, or 3.3 V from a 3.3 V supply at the power levels shown in
3 14
Table 1. These devices eliminate the need for a separate, isolated
ADuM5202W VOB VIB
004 dc-to-dc converter in low power isolated designs. The iCoupler
4 13
10436- chip-scale transformer technology is used to isolate the logic Figure 4. ADuM5202W signals and for the magnetic components of the dc-to-dc converter. The result is a small form factor, total isolation solution.
Table 1. Power Levels
The ADuM5200W/ADuM5201W/ADuM5202W isolators
Input Voltage (V) Output Voltage (V) Output Power (mW)
provide two independent isolation channels in a variety of channel 5.0 5.0 400 configurations and data rates (see the Ordering Guide for more 5.0 3.3 330 information). 3.3 3.3 122 isoPower uses high frequency switching elements to transfer power through its transformer. Special care must be taken during printed circuit board (PCB) layout to meet emissions standards. See the AN-0971 Application Note for board layout recommendations. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 6,903,578; and 7,075,329.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2012 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Package Characteristics Regulatory Information Insulation and Safety-Related Specifications IEC 60747-5-2 (VDE 0884, Part 2):2003-01 Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table Typical Performance Characteristics Terminology Applications Information PCB Layout Start-Up Behavior EMI Considerations Propagation Delay Parameters DC Correctness and Magnetic Field Immunity Power Consumption Current Limit and Thermal Overload Protection Power Considerations Thermal Analysis Increasing Available Power Insulation Lifetime Outline Dimensions Ordering Guide Automotive Products
