Datasheet ADUM5000 (Analog Devices)
Description | 2.5 kV, Isolated DC-to-DC Converter |
Pages / Page | 16 / 1 — 2.5 kV, Isolated DC-to-DC Converter. Data Sheet. ADuM5000. FEATURES. … |
Revision | B |
File Format / Size | PDF / 335 Kb |
2.5 kV, Isolated DC-to-DC Converter. Data Sheet. ADuM5000. FEATURES. FUNCTIONAL BLOCK DIAGRAM. iso
link to page 1 link to page 1
2.5 kV, Isolated DC-to-DC Converter Data Sheet ADuM5000 FEATURES FUNCTIONAL BLOCK DIAGRAM iso Power integrated, isolated dc-to-dc converter VDD1 1 OSC RECT REG 16 VISO Regulated 3.3 V or 5 V output Up to 500 mW output power GND1 2 15 GNDISO 16-lead SOIC package with 7.6 mm creepage NC 3 14 NC High temperature operation: 105°C maximum Thermal overload protection RCIN 4 13 VSEL Safety and regulatory approvals RCOUT 5 12 NC UL recognition 2500 V rms for 1 minute per UL 1577 RCSEL 6 11 NC CSA Component Acceptance Notice #5A VDD1 7 10 VISO VDE certificate of conformity (pending)
01 0
GND 8 9 GND
9-
IEC 60747-5-2 (VDE 0884, Part 2) 1 ADuM5000 ISO
53 07
VIORM = 560 V peak
Figure 1.
APPLICATIONS RS-232/RS-422/RS-485 transceivers Industrial field bus isolation Power supply startups and gate drives Isolated sensor interfaces Industrial PLCs GENERAL DESCRIPTION
The ADuM50001 is an isolated dc-to-dc converter based on isoPower uses high frequency switching elements to transfer power the Analog Devices, Inc., iCoupler® technology. The dc-to-dc through its transformer. Special care must be taken during printed converter in this device provides regulated, isolated power in circuit board (PCB) layout to meet emissions standards. See the several combinations of input and output voltages as listed in AN-0971 Application Note for board layout recommendations. Table 1.
Table 1.
The Analog Devices chip scale transformer, iCoupler technology,
Input Voltage (V) Output Voltage (V) Output Power (mW)
transfers isolated power in this dc-to-dc converter with up to 5 5 500 33% efficiency. The result is a small form factor, total isolation 5 3.3 330 solution. 3.3 3.3 200 Higher output power levels are obtained by using the ADuM5000 to augment the power output of ADuM5401, ADuM5402, ADuM5403, ADuM5404, ADuM520x, and other ADuM5000 iCouplers with isoPower®. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 6,903,578; and 7,075,329.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices fo r its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2008–2012 Analog Devices, Inc. Al l rights reserved.
Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Package Characteristics Regulatory Information Insulation and Safety-Related Specifications IEC 60747-5-2 (VDE 0884, Part 2):2003-01 Insulation Characteristics Thermal Derating Curve Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information PCB Layout Start-Up Behavior EMI Considerations Thermal Analysis Current Limit and Thermal Overload Protection Power Considerations Increasing Available Power Insulation Lifetime Outline Dimensions Ordering Guide
