Datasheet LM258, LM358, LM358A, LM358E, LM2904, LM2904A, LM2904E, LM2904V, NCV2904 (ON Semiconductor) - 4
ManufacturerON Semiconductor
DescriptionSingle Supply Dual Operational Amplifiers
Pages / Page14 / 4 — LM258, LM358, LM358A, LM358E, LM2904, LM2904A, LM2904E, LM2904V, NCV2904. …
Revision32
File Format / SizePDF / 140 Kb
LM258, LM358, LM358A, LM358E, LM2904, LM2904A, LM2904E, LM2904V, NCV2904. ELECTRICAL CHARACTERISTICS. LM258. LM358, LM358E
LM258, LM358, LM358A, LM358E, LM2904, LM2904A, LM2904E, LM2904V, NCV2904 ELECTRICAL CHARACTERISTICS LM258 LM358, LM358E
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
(VCC = 5.0 V, VEE = GND, TA = 25°C, unless otherwise noted.)
LM258 LM358, LM358E LM358A Characteristic Symbol Min Typ Max Min Typ Max Min Typ Max Unit
Input Offset Voltage VIO mV VCC = 5.0 V to 30 V, VIC = 0 V to VCC −1.7 V, VO ] 1.4 V, RS = 0 TA = 25°C − 2.0 5.0 − 2.0 7.0 − 2.0 3.0 TA = Thigh (Note 4) − − 7.0 − − 9.0 − − 5.0 TA = Tlow (Note 4) − − 7.0 − − 9.0 − − 5.0 Average Temperature Coefficient of Input Offset VIO/T − 7.0 − − 7.0 − − 7.0 − V/°C Voltage TA = Thigh to Tlow (Note 4) Input Offset Current IIO − 3.0 30 − 5.0 50 − 5.0 30 nA TA = Thigh to Tlow (Note 4) − − 100 − − 150 − − 75 Input Bias Current IIB − −45 −150 − −45 −250 − −45 −100 TA = Thigh to Tlow (Note 4) − −50 −300 − −50 −500 − −50 −200 Average Temperature Coefficient of Input Offset IIO/T − 10 − − 10 − − 10 − pA/°C Current TA = Thigh to Tlow (Note 4) Input Common Mode Voltage Range (Note 5), VICR 0 − 28.3 0 − 28.3 0 − 28.5 V VCC = 30 V VCC = 30 V, TA = Thigh to Tlow 0 − 28 0 − 28 0 − 28 Differential Input Voltage Range VIDR − − VCC − − VCC − − VCC V Large Signal Open Loop Voltage Gain AVOL V/mV RL = 2.0 k, VCC = 15 V, For Large VO Swing, 50 100 − 25 100 − 25 100 − TA = Thigh to Tlow (Note 4) 25 − − 15 − − 15 − − Channel Separation CS − −120 − − −120 − − −120 − dB 1.0 kHz ≤ f ≤ 20 kHz, Input Referenced Common Mode Rejection CMR 70 85 − 65 70 − 65 70 − dB RS ≤ 10 k Power Supply Rejection PSR 65 100 − 65 100 − 65 100 − dB Output Voltage−High Limit VOH V TA = Thigh to Tlow (Note 4) VCC = 5.0 V, RL = 2.0 k, TA = 25°C 3.3 3.5 − 3.3 3.5 − 3.3 3.5 − VCC = 30 V, RL = 2.0 k 26 − − 26 − − 26 − − VCC = 30 V, RL = 10 k 27 28 − 27 28 − 27 28 − Output Voltage−Low Limit VOL − 5.0 20 − 5.0 20 − 5.0 20 mV VCC = 5.0 V, RL = 10 k, TA = Thigh to Tlow (Note 4) Output Source Current IO+ mA VID = +1.0 V, VCC = 15 V 20 40 − 20 40 − 20 40 − TA = Thigh to Tlow (LM358A Only) 10 − − Output Sink Current IO− VID = −1.0 V, VCC = 15 V 10 20 − 10 20 − 10 20 − mA TA = Thigh to Tlow (LM358A Only) 5.0 − − mA VID = −1.0 V, VO = 200 mV 12 50 − 12 50 − 12 50 − A Output Short Circuit to Ground (Note 6) ISC − 40 60 − 40 60 − 40 60 mA Power Supply Current (Total Device) ICC mA TA = Thigh to Tlow (Note 4) VCC = 30 V, VO = 0 V, RL = ∞ − 1.5 3.0 − 1.5 3.0 − 1.5 2.0 VCC = 5 V, VO = 0 V, RL = ∞ − 0.7 1.2 − 0.7 1.2 − 0.7 1.2 4. LM258: Tlow = −25°C, Thigh = +85°C LM358, LM358A, LM358E: Tlow = 0°C, Thigh = +70°C LM2904/A/E: Tlow = −40°C, Thigh = +105°C LM2904V & NCV2904: Tlow = −40°C, Thigh = +125°C NCV2904 is qualified for automotive use. 5. The input common mode voltage or either input signal voltage should not be allowed to go negative by more than 0.3 V. The upper end of the common mode voltage range is VCC − 1.7 V. 6. Short circuits from the output to VCC can cause excessive heating and eventual destruction. Destructive dissipation can result from simultaneous shorts on all amplifiers.
www.onsemi.com 4
