Datasheet LT1027LS8 (Analog Devices) - 2
DescriptionPrecision, Low Noise, High Stability Hermetic Voltage Reference
Pages / Page14 / 2 — absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion. …
File Format / SizePDF / 3.1 Mb
absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion. (http://www.linear.com/product/LT1027LS8#orderinfo
absoluTe MaxiMuM raTings pin conFiguraTion (Note 1) orDer inForMaTion (http://www.linear.com/product/LT1027LS8#orderinfo
LT1027LS8
Input Voltage ...40V TOP VIEW V Input/Output Voltage Differential ..35V IN Output to Ground Voltage ...7V 8 NR 1 7 NC* VTRIM to Ground Voltage Positive ...5V VOUT 2 6 NC* Negative ...–0.3V VTRIM 3 5 NC* 4 Output Short-Circuit Duration GND VIN > 20V ..10 sec LS8 PACKAGE V 8-PIN LEADLESS CHIP CARRIER (5mm × 5mm) IN ≤ 20V ... Indefinite Operating Temperature Range CONNECTED INTERNALLY. *D0 NOT CONNECT EXTERNAL LT1027C ... 0°C to 70°C CIRCUITRY TO THESE PINS LT1027I ..–40°C to 85°C SEE APPLICATIONS **INFORMATION SECTION Storage Temperature Range .. –65°C to 150°C TJMAX = 125°C, θJA = 120°C/W PACKAGE LID IS GND
orDer inForMaTion (http://www.linear.com/product/LT1027LS8#orderinfo ) LEAD FREE FINISH PART MARKING PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT1027DCLS8-5#PBF 10275 8-Lead Ceramic LCC 5mm × 5mm 0°C to 70°C LT1027DILS8-5#PBF 10275 8-Lead Ceramic LCC 5mm × 5mm –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 1027ls8f 2 For more information www.linear.com/LT1027LS8 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
