Datasheet ADR225 (Analog Devices)
Description | High Temperature, Low Drift, Micropower, 2.5V Reference |
Pages / Page | 12 / 1 — High Temperature, Low Drift,. Micropower 2.5 V Reference. Data Sheet. … |
Revision | B |
File Format / Size | PDF / 243 Kb |
High Temperature, Low Drift,. Micropower 2.5 V Reference. Data Sheet. ADR225. FEATURES. PIN CONFIGURATION
High Temperature, Low Drift, Micropower 2.5 V Reference Data Sheet ADR225 FEATURES PIN CONFIGURATION Extreme high temperature operation NC 1 8 NC −40°C to +210°C, 8-lead FLATPACK V ADR225 S 2 7 NC −40°C to +175°C, 8-lead SOIC NC TOP VIEW 3 6 OUTPUT (Not to Scale) Temperature coefficient GND 4 5 NC 40 ppm/°C, 8-lead FLATPACK NOTES 10 ppm/°C, 8-lead SOIC
001
1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN.
1525-
High output current: 10 mA
1 Figure 1. Pin Configuration for SOIC and FLATPACK Packages
Low supply current: 50 µA maximum Initial accuracy: ±0.4% (±10 mV maximum), 8-lead SOIC Low dropout voltage Wide supply range: 3.3 V to 16 V APPLICATIONS Down-hole drilling and instrumentation Avionics Heavy industrial High temperature environments GENERAL DESCRIPTION
The ADR225 is a precision 2.5 V band gap voltage reference It is also available in an 8-lead ceramic flat pack (FLATPACK) specified for a high temperature operation of 175°C and 210°C. with an operating temperature range of −40°C to +210°C. Both It uses a micropower core topology and laser trimming of highly devices are designed for robustness at extreme temperatures stable, thin film resistors to achieve a temperature coefficient of and are qualified for 1000 hours of operation at the maximum 30 ppm/°C (maximum) up to 175°C and an initial accuracy of 0.4% temperature rating. (±10 mV maximum). A maximum operating current of 50 µA The ADR225 is a member of a growing series of high temperature and a low dropout voltage allow the ADR225 to function very qualified products offered by Analog Devices, Inc. For a complete well in battery-powered equipment. selection table of the available high temperature products, see The ADR225 voltage reference is offered in an 8-lead SOIC the high temperature product list and qualification data available package with an operating temperature range of −40°C to +175°C. at www.analog.com/hightemp.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Pin Configuration General Description Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Predicted Lifetime vs. Operating Temperature Thermal Resistance ESD Caution Typical Performance Characteristics Theory of Operation Basic Voltage Reference Connections Outline Dimensions Ordering Guide
