Datasheet LT1236LS8 (Analog Devices) - 2
DescriptionPrecision, Low Noise, Low Profile Hermetic Voltage Reference
Pages / Page16 / 2 — absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion …
File Format / SizePDF / 233 Kb
absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion LEAD FREE FINISH. PART MARKING*. PACKAGE DESCRIPTION
absoluTe MaxiMuM raTings pin conFiguraTion (Note 1) orDer inForMaTion LEAD FREE FINISH PART MARKING* PACKAGE DESCRIPTION
LT1236LS8
Input Voltage ...40V TOP VIEW NC* Input/Output Voltage Differential ..35V Trim Pin-to-Ground Voltage 8 NC* 1 7 NC* Positive ... Equal to VOUT VIN 2 6 VOUT Negative ..–20V Output Short-Circuit Duration NC* 3 5 TRIM** 4 VIN = 35V ..10 sec GND VIN ≤ 20V ... Indefinite LS8 PACKAGE 8-PIN LEADLESS CHIP CARRIER (5mm × 5mm) Operating Temperature Range ...–40°C to 85°C CONNECTED INTERNALLY. * Storage Temperature Range .. –65°C to 150°C D0 NOT CONNECT EXTERNAL CIRCUITRY TO THESE PINS SEE APPLICATIONS **INFORMATION SECTION TJMAX = 125°C, θJA = 120°C/W PACKAGE LID IS GND
orDer inForMaTion LEAD FREE FINISH PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT1236AILS8-5#PBF† 12365 8-Lead Ceramic LCC 5mm × 5mm –40°C to 85°C LT1236BILS8-5#PBF† 12365 8-Lead Ceramic LCC 5mm × 5mm –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ †This product is only offered in trays. For more information go to: http://www.linear.com/packaging/
elecTrical characTerisTics The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN = 10V, IOUT = 0, unless otherwise noted. LT1236LS8-5 PARAMETER CONDITIONS MIN TYP MAX UNITS
Output Voltage (Note 2) LT1236ALS8 4.9975 5.000 5.0025 V LT1236BLS8 4.9950 5.000 5.0050 V Output Voltage Temperature Coefficient (Note 3) LT1236ALS8 2 5 ppm/°C LT1236BLS8 5 10 ppm/°C Line Regulation (Note 4) 7.2V ≤ VIN ≤ 10V 4 12 ppm/V l 20 ppm/V 10V ≤ VIN ≤ 40V 2 6 ppm/V l 10 ppm/V Load Regulation (Sourcing Current) 0 ≤ IOUT ≤ 10mA 15 25 ppm/mA (Note 4) l 40 ppm/mA 1236ls8f 2 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
